zanepetty
753 resto completion KINDA..
zanepetty
First off thank everyone for helping me along the way with this resto. Couldn't have done it with out you guys. I stayed up late and tried my tractor. NO LEAKS! I rode it around for half an hour last night!too dark for any good pics. BUT if the engine is at idle speed, and I'm in high speed it will bog down and die on a steep hill..does that mean something DID break on my governor after all?
rmaynard
What does it do when you give it more throttle?
zanepetty
Goes right up the hill, bob
rmaynard
I don't think there is anything wrong. That's what the throttle is for. Don't expect the governor to do all the work for you. It's job is to keep the engine from over-revving, and to maintain engine speed. But it is not meant to set the engine to the correct speed for the job.
zanepetty
OK that's good news. Maybe I'm being paranoid because I was nervous about that. I just didn't hear the engine try not to die or pull harder but maybe it shouldn't at idle?
bmsgaffer
If you are in high gear and the engine is just idling there is not much torque there to work with. It will die in short order (the governer can only adjust so much and it usually doesnt have a chance to catch up when idling). I have a great running 12hp that will do the same.
The tractors are designed to be running at 3/4 to full throttle for most applications and just let the gearing and clutch change the ground speed. :handgestures-thumbupright:
I think that the 'snap' that you heard (or felt) was just you overcoming the static friction on the screw threads as you were tightening it. The same thing happens sometimes when you put a 3.5" screw into a piece of pine. After you get it in there so tight, every time you turn the screw you will feel a little 'snap' as you overcome the static friction on the threads.
Edited by bmsgaffer
zanepetty
Oh OK. Well I hope so! Thanks. I really don't want to have to tear into my motor ;/
  • Similar Content
    • cJ_3D
      By cJ_3D
      Hey all!
      Replacing the drive belt on my 252-h. Anyone know the torque specification for the center screw when I put this pto clutch back on? I know it was on there tight it took a minute for the impact to break it loose. Thanks!
      CJ
    • bkarp@roadrunner.com
      By bkarp@roadrunner.com
      my magnum 12 kohler all of a sudden is blowing oil out of the carb. if rings are bad should oil be blowing out of the muffler.thanks for any help brent
    • Tinman1962
      By Tinman1962
      Recently got hold of a 656 it's has a "newer" 61/2 Briggs on it I don't believe that's right any ideas about that
    • Little Red Horse
      By Little Red Horse
      Hey all. I have a Electro 12 with a factory belly blade. It runs* and drives. I had used it to grade my driveway the last 6 yrs. Having moved I'm looking at my options on storing it or selling it. Frankly I have no idea what it is worth. I watched "ISaveTractors" video on 5 things to do with a new to you wheel horse/12hp kohler. (When i got it 6yrs ago) And went thru and did the adjustments and replaced the parts mentioned. It has been a good strong tractor for me until around July of this year. (2023)
      *Around July it started dying after running 20-30min. I replaced the carb (Chinese Amazon purchase) with one from isavetractors web site. That seemed to help it idle smoother(the old carbs jets wouldnt adjust), but it still dies at around 20-30min.
      So I've got 2 questions.
      1. What is it worth? (As-Is) and
      2. What do I need to do to fix it?
      Thanks yall!
    • 850ford
      By 850ford
      I am looking for a replacement Kohler for a 1980 c165,it is cradle mounted.
      Will a standard mount Kohler work, if I remove the cradle?
       I am located in Massachusetts
        Thanks
