wheelhorsekid 141 #26 Posted February 4, 2014 Sounds like you need another tire shop, I mount all my own tires by hand, I have put to wide a tire on a narrow rim and too narrow a tire on a wide rim, some take more work than others but they fit. Another note off brand tires run a little small and fit the narrow rims better, a true 10.5 tire will fit best on a 8.5 rim, I have off brands on the standard 7" rims with no problem but the tread does not lay as flat as it would on a wider rim. I have 7" wide rims and they are telling me my new 10.5" tires won't fit. I called him today and he said the bead kept popping off one side when he was trying to get the other side on. I am going to buy brand new 520H rims for $124 each. They are still available. Share this post Link to post Share on other sites
Navig8r 132 #27 Posted February 4, 2014 I have 7" wide rims and they are telling me my new 10.5" tires won't fit. I called him today and he said the bead kept popping off one side when he was trying to get the other side on. I am going to buy brand new 520H rims for $124 each. They are still available. So he couldnt get the beads to 'push out' against the rim? Am I understanding that right? If so, my next question is, are we talking about an actual tire shop? Have you tried seating them yourself with a ratchet strap? Like this: If I am understanding you correctly, when the tire is not seated, the beads are too far from the rim to seat them..... If that is the case, a wider rim is going to make the tire more difficult to seat, not less! 1 Share this post Link to post Share on other sites
AMC RULES 37,146 #28 Posted February 4, 2014 Too much like work, lazy installer there...that's all. OOPS...did I say that out LOUD? 2 Share this post Link to post Share on other sites
varosd 1,185 #29 Posted February 4, 2014 This whole thing has me confused now….520's had 8.5 inch rims and the popping off thing has me lost as well. To me it sounds like a tire tech that has no real clue how to do his job. I have never had these issues and I do my tires myself except for the 6 ply tires on the 18 Automatic rear..those were mounted for me Jeff, My 1988 520 only has the 7" rim, it was 8.5 for the 520-HC. later 520's (not sure when) all had the 8.5" rim. Share this post Link to post Share on other sites
Hodge71 665 #30 Posted February 5, 2014 Jeff, My 1988 520 only has the 7" rim, it was 8.5 for the 520-HC. later 520's (not sure when) all had the 8.5" rim. I didn't know that Don…Thanks for keeping me straight… Share this post Link to post Share on other sites
can whlvr 993 #31 Posted February 5, 2014 ive used the strap method,also a piece of wire rope and twist it with a pry bar,then hit the tire with a hammer while putting the air to her,i made an air nozzle filler with no center piece in it,i took it out so when you turn on the air it pumps air with out having to push it against the valve stem,take out the valve out of the tire trying to be seated and it will get max air flow,once the bead seats then the valve can be put back in Share this post Link to post Share on other sites
flyovrcntry 115 #32 Posted February 5, 2014 Yeah I don't see how a 12" tire is popping off a 12" rim,the width should not matter,the tire would just be rounded. Share this post Link to post Share on other sites
baerpath 517 #33 Posted February 5, 2014 Before I would spend $248 for new rims I would go to another shop and have them mounted. Sounds like all they need is the side walls blown out to catch. Were the side walls crushed in when you got them? 2 Share this post Link to post Share on other sites
Kelly 1,030 #34 Posted February 5, 2014 $20 in tubes could solve the problem also. 3 Share this post Link to post Share on other sites
wheelhorsekid 141 #35 Posted February 5, 2014 So he couldnt get the beads to 'push out' against the rim? Am I understanding that right? If so, my next question is, are we talking about an actual tire shop? Have you tried seating them yourself with a ratchet strap? Like this: If I am understanding you correctly, when the tire is not seated, the beads are too far from the rim to seat them..... If that is the case, a wider rim is going to make the tire more difficult to seat, not less! I'm going to a new shop when the snow stops. You're right it doesn't make sense. Thanks for the tips. and advice. Share this post Link to post Share on other sites
Callen 64 #36 Posted February 5, 2014 Sounds like the installer can't get the bead to stay down under the rim edge as he tries to put it on. Share this post Link to post Share on other sites
wallfish 17,494 #37 Posted February 5, 2014 $20 in tubes could solve the problem also. X2 Share this post Link to post Share on other sites
Irv 115 #38 Posted February 5, 2014 When you get new tires, especially if they are shipped to you, they come somewhat flattened, especially at the bead. I spread the bead and put pieces of 2 x 4 (about 10" long) at 3 or 4 places to hold the bead spread and put them in a warm place for a few days. When I mount them, I take the valve stem out of the valve so that I am getting the full shot of air to help seat the bead. 1 Share this post Link to post Share on other sites
SousaKerry 502 #39 Posted February 5, 2014 I use the ratchet strap method all the time especially with old dried out front tires that break loose from the bead just let the air back out once you seat the bead or when you let the strap go you may loose some skin or a finger. I found out the hard way. Share this post Link to post Share on other sites
KATO 115 #40 Posted February 5, 2014 UH HUH been there done that!! Share this post Link to post Share on other sites
baerpath 517 #41 Posted February 5, 2014 When we mount 26x12's on 14 inch wide rims we blow a tube up in them off the rim for a week, to get the bead streatched out to where we need them to mount. And sometimes use a bead tank to blow them out while mounting Share this post Link to post Share on other sites
flyovrcntry 115 #42 Posted February 5, 2014 (edited) http://www.youtube.com/watch?v=7owrxqMFSy8 Edited February 5, 2014 by flyovrcntry Share this post Link to post Share on other sites
WH nut 553 #43 Posted February 5, 2014 You can always use a little starting fluid. Fun stuff lol 1 Share this post Link to post Share on other sites
oaktown1987 82 #44 Posted February 7, 2014 B100 with 10.5 tires Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
wheelhorsekid 141 #45 Posted February 11, 2014 Okay I got the tires on the rim with a tube. The guy I took the tires to really didn't know what he was talking about. I'll post some pictures soon, 1 Share this post Link to post Share on other sites
Kelly 1,030 #46 Posted February 11, 2014 Glad you got it, some places if it don't fit the tire machine don't want to mess with it, or sad to say don't know how. Share this post Link to post Share on other sites
oaktown1987 82 #48 Posted September 27, 2014 I got carlysles on stock rims Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
