WHEEL HORSE BILL
C-101 no spark and getting (MAD)
WHEEL HORSE BILL
Hi guys i have a c-101 with no spark I changed the coil,points reset to .20 and also canged the condencer nothing no spark.
what else can I change or do.I bought it with a this problem but still can't figure it out.
Tom.
Hi,
Not often the problem but could it be the spark plug? Check its clean and gapped correctly, I have had this before and it's just been a case of a dud spark plug.
Tom
WHEEL HORSE BILL
It's a new plug.
rmaynard
The power to the coil goes through the PTO interlock. I would try connecting a wire directly from the (+) terminal of the battery to the (+) terminal of the coil. See if it starts. If so, there is something open in the wiring from the ignition switch to the coil. Attached is the wiring diagram for your C-101.
Don't forget to remove the wire after the test, as you will either burn up the coil or drain your battery if the points are in a closed position.
post-2221-0-96362200-1391450415_thumb.jp
nylyon
Make sure that you have 12v at the positive side of the coil.
WHEEL HORSE BILL
Ok I think I know the cause.All the switches are gone, seat safety switch was bypassed one loop the brake switch was also bypassed with loop and the pto clutch switch was by passed with only one wire cause going to one terminal to another this could be the problem.I think the pto clutch switch is messed up.I may have to retrace my wiring.
Edited by WHEEL HORSE BILL
WHEEL HORSE BILL
I'm gonna post some pictures of the problem im having on facebook.I don't know how to post pictures here.For some reason it's not down loading.
Jparkes43
I bypassed some of my switches and did it wrong and that stopped it from starting,
James
Tom.
Hi,
To upload photos you will need a photobucket account. Just create a photobucket account, upload the images to their and then copy the IMG code and paste it onto here, that should work then. If not just post up any problems you are having.
You probably already have but make sure all connections are clean and tight, sometimes it's simply a loose or dirty connection.
Tom
Jparkes43
Hi,
Tom
Or just upload to the gallery and use goose files to import to the thread, that is what I do
James
Edited by Jparkes43
WHEEL HORSE BILL
I'll just post it to facebook under redsquare page
WHEEL HORSE BILL
Pictures are on facebook under redsquare page
rmaynard
Some of us don't use Facebook. It would be nice if you would upload them here. It is very easy. Just use the "more reply options" and where it says attach file at the bottom, click the "choose file" button, select the file to upload and when it has completed, just click the attach file link next to the file.
skrusins
I have had a brand new plug that was a dud, also I didn't know if you check to see if you have 12v at the points.
They may have oil or film  on them. I always was told to slide a paper money bill between the contacts to clean.
WHEEL HORSE BILL
Here are the pictures That all you guys wanted to see.Can you see anything wrong.post-5677-0-70541800-1391480877.jpgpost-5677-0-13522100-1391481295.jpgpost-5677-0-08747500-1391481429.jpgpost-5677-0-10761100-1391481550.jpgpost-5677-0-14522900-1391481632.jpg
rmaynard
Hard to tell anything from the pictures, but as I suggested earlier, just make a jumper by taking a piece of 14 or 16 gauge wire and go directly from the (+) terminal of the battery to the (+) terminal of the coil. That's the quickest way to test it. If it starts, then you know that the coil, condenser, points, plug and plug wire are okay. Then you can take a meter and check the rest of the wiring as shown in the diagram to see where the problem is. On the other hand, if it doesn't fire by using the jumper wire, you can safely assume that either the coil, condenser, points, plug or plug wire are bad.
  • Like 5
WH nut
Best answer right there^
WHEEL HORSE BILL
Picture #1 shows the one wire they used to jump it.The rest of the prongs go to nothing if you look carefully
Then pictures #2 shows the seat and brake also jumped.
Maynard I tried doing the single wire. It turns over but has no spark.
I really think it's the pto clutch switch there is none and I think it needs a complete curcuit the get spark.
rmaynard
If you used the jumper directly to the coil and you have no spark, then you either have a bad coil, wrong coil, bad or improperly adjusted points, bad condenser, bad wire to the points, bad spark plug, or bad spark plug wire.
By using the jumper, you are eliminating all other possible wiring problems such as safety switches, ignition switches, etc.
Ed Kennell
Bill, listen to Bob.  By jumping 12v directly to the coil from the battery, you eliminate all the switches, wiring and connections that cause 99% of the problems. All that is left is the plug,points,condenser,coil, and the wiring connecting these components.     If It doesn't fire with the jumper on,  check the coil/plug wire and the coil/points wire for continuity. If they are good, install new plug, points and condenser ... they are cheap.   If still no fire, replace the coil.  If it still does not fire, you did something wrong....recheck the two wires.
Hodge71
:deadhorse:  :text-yeahthat:  PLease listen to what we are trying to tell you. Run the jumper from the positive battery terminal to the positive side of the coil. It will eliminate all your bypasses and tell you if everything is ok.
WH nut
One thing is for sure. If you replace enough parts you are bound to stumble across the bad one.
WHEEL HORSE BILL
I've tried everything still nothing can someone please call me 401 339-6570.just went out and bought new points also still nothing.is there a way to test coils.I have a new on there but maybe i'st bad I got spark to the points what else can to do.
WHEEL HORSE BILL
I need this beast for tomorrows storm.
WHEEL HORSE BILL
Ok I put a wire from +positive to the coil positive again and it worked this time.I don't know what happened last time sorry.But now what do you guys think is wrong the wiring
  • Similar Content
    • Tenday
      By Tenday
      Experts - help please. I’m new to Wheel Horse Tractor life!
      So - I’ve pulled out an inherited tractor and have decided to resurrect her. Unfortunately, no spark :/
      I’m looking for help on diagnosing no spark.
      model - 417-8
      engine - Kohler KT17
      Done thus far:  (aware that some have no implication on spark.)
      - new ignition switch
      - new battery
      - new starter
      - new ignition coil and wires w/ plugs
      - new condenser
      - new points
      - new starter solenoid
      - bypassed all switches except oil and seat.
      notes:
      idiot lights removed.
      All fuses tested with Ohms as well as visual inspection  ..
      coil tested w/ ohms as well
      all switches bypassed except:
      -oil switch  ( don’t think it has any implications other than a visual indication for idiot lights. )
      -seat switch
      ran a pos from batt direct to pos of coil - nothing; no spark.
      Electric is as follows:
      - Starter switch wired to solenoid
      - - solenoid to starter
      - - solenoid to batt
      - one wire from starter switch goes to engine ( I think this is for batt charge / flywheel)
      - I have two yellow wires, which are married up, that go to engine which have constant power; They power coil.  Comes from switch and seat.
      Help - what the heck am I missing ?
    • Rollo416H
      By Rollo416H
      I'm new here, but I have years and miles of dealing with electrical issues with my 1997 416H, engine Onan P216G (I am the only owner) . Problem description: the start circuit turns the starter over fine, but no spark at the plugs or the coil sockets by spark tester.  The ignition trigger tests good by connecting a test light to the coil positive and and the ignition trigger negative lead, plenty of light flash from the test light in unison with the engine turning over. So, I conclude the ignition trigger, replaced 3/18/2021 along with the coil is good.  I have followed the "Demystification" wiring diagram in detail and there is 12V at the coil positive terminal, wiriing is solid (for now), all those damn safety switches, key switch,  and relays work too. I conclude that the coil is bad since the primary side tests 3.1 OHM and the secondary tests infinite OHMS (1. displayed on multimeter).  Two coils (Onan part# 166-0820) have NEW dates of 3/2021 and 8/2021, and yes both have the same test results mentioned. Infinite OHMs to me means the coil windings are broken. The most recent coil came from Onanparts.com and tested as mentioned above when it arrived.  Onanparts won't take anything back!  There are a lot of coils on ebay and various suppliers from China.  Maybe good, maybe bad, who can tell? And most suppliers won't accept returned electrical parts. Please help: What are good test readings for a GOOD coil (primary and secondary). Who do you recommend as a reliable supplier for a new coil?
      Thanks for any help!
      Rollo416H
    • Don66
      By Don66
      I have a 1978 Wheel Horse 8 speed tractor,Kohler 321 engine. I've been working on restoration, finally got the mower deck finished and installed. Before this, the engine was easy to start and ran well. Yesterday it would not start with ignition key, would not even turn over, so I jumped it with a screwdriver between cylinoid and battery. The engine started and ran about 10 seconds and died. Now I get no spark and the engine won't fire off. I checked the wiring and everything seems to be connected and without damage. I don't have test equipment available so I'm stumped at what went wrong. Any suggestions?
    • DHack
      By DHack
      Hello,
      My first Wheel Horse project and new to this form. Any help would be greatly appreciated. I purchased older farm house and this gem was negotiated as part of the deal.
      I believe I have a ~1962/1963 Rounded hood Wheel Horse with Tecumseh engine.
      Can anyone determine the model / Year?
      Got this running with new carbonator and basic tune-up, but now not getting any spark.
      I am not sure how the points/elec ignition is supposed to work but not getting any voltage reading (.02V) when cranking. Fuse is good, but not sure about resister/capacitors.
      Seems like maybe coil within flywheel could bad, but not sure how to get the fly wheel off to check this further.
      Anyone have seen similar issue that would help me troubleshoot further?
      I'm thinking of putting in a replacement engine if anyone could send me info related to what would work for a replacement?
      Serial Number below dash is 62-12492
      There are two tags on the engine
      Tag above starter (SBH-169C     4313F)
      Tag on front of engine (SBH-169B    2133F)
      Thanks
      Dan
    • Muddyfeet
      By Muddyfeet
      BeOk first off I have a older 80 400 series .  Was my father's and I am attached to the old lady.. it Was running ok..
      This year after a year outside  it just will not start. I am Not a mechanic so working blind.
      I have the seat switch bypassed, also the PTO saftey switch. Replaced a lot of little parts,.Don't know if there is something else . so.. history aside.. cranks  no start.. using a test light.love my test light.. fixed a lot on some older engines with this.. anyway. Test light not meter. I get power to the points. Power. To the + end of the coil.. a flashing on the neg side of the coil when cranking.. I do get power after cranking on the neg end of the coil.. the two posts not where the spark plugs wires come out.. I do see A white spark seen and heard at the points when cranking and if I pull the points apart when not cranking .. using test light or inline spark plugs test nothing. have not done the pull  plug and ground to see.. but using test light I put in on the cable no light.. no light on the coil tower either.. I replaced the coil, condensor and points like 8 years ago I think.. it was hard to start and I was using the manual..
      So no spark if power to the coil but nothing out equals bad coil right??  Well the local shops quote for 280 for a coil was a shock. . but looked online hard to find but a little less..
      Cannot rember what I spent before..
      So worth buying a coil and if so may as well replace points and condensor at same time?? Am I missing something?? Got power going into this and nothing out as I can see.. but heck what to I know..
