Uncle Buck
wheel weight question
Uncle Buck
Aside from genuine WH wheel weights, what other brands are possible considerations for an 857 wh?
Would current Sears wheel weights work on my old 857?
876wheelhorse
prob if you have a 12 inch wheel like most garden tractors do they will fit like john deere weights fit on a horse sears etc.....
chevyaddict83
I hate to admit i have plastic crapsmen weights on one of mine. But the price was right.
Sent from my LG-LS980 using Tapatalk
Kelly
ANY weight made for a 12" wheel will fit with the right bolts, I have a pallet full of weights I can ship most of them, even a set of real WH weights send me a PM for more info
varosd
also guilty of having "yellow" plastic rears on.  they are the 80 pound or so ones that came off 400 series JD.  they are on the 520 and the 416 has the plastic WH weights.  now have rubber chains on both rigs
squonk
Red paint in spray cans can cover all types of sins!  :)  :ychain:
Edited by squonk
leeave96
I have two sets of plastic wheel weights - one with a tacky/flaking-off paper Wheelhorse decal and the other set is identical, is MTD and has no sticker.  I've had great luck with them sometimes you can find them where the price is right.  I bought my MTD weights several years at a Lowes and they were marked clearance for $25, including all mounting hardware.
bmsgaffer
I have a set of 40# (i think) plastic original wheel horse weights. They show some wear and tear but work just the same. PM me if you are interested.
indawire
I've got a set of the plastic ones w/ the WH logo I found at the dump (er, I meant the transfer station).
over60pirate
Barbell weights
post-6550-0-11238200-1395107030_thumb.jp
Tankman
Brake drums and carriage bolts. Although I had cast WH weights, son "needed" them, was easy enough to make a pair. Concrete filled 'bout fifty pounds each.
Edited by Tankman
Stigian
Brake drums filled with concrete... I like your thinking :D
  • Similar Content
    • 2drxploder
      By 2drxploder
      looking for a tiller for my 520h as well as some wheel weights. also maybe some good chrome hubcaps
      located in charlotte nc area
    • t_furl43
      By t_furl43
      A Wheelhorse C-165 8 speed, nice solid tractor everything works and operates as it should, all lights works(stack will be removed before sale)unknown hours it was only an option for the 165, but the 16hp single lung cast iron K series motor starts right up and runs strong. It will need new motor mounts. Transmission shifts smooth, package comes with plow w/optional down pressure bar if you choose instead of your trunnions chain, a set of tire chains, a set of Toro brand front wheel weights and a set of generic rear wheel weights, and lastly a full set of hub caps that are in decent shape they can be cleaned up, $1000 obo. Would like to sell as package but if the right buyer was interested in the right combo of stuff for the right amount of money we could work something out. Pickup only in Millersville PA 17551
    • Ifixoldjunk
      By Ifixoldjunk
      so I spent a few hours today welding up a custom front weight bracket for my 310-8. It has two and a half inches of ground clearance with a generic 12 inch weight bolted on.
      so the question is, how well do y’all think the 300 series front axle will hold the weight? It’s only 50lbs so it’s lighter than the snowblower it has to hold up in winter so I don’t think I’ll have any problems. And I really don’t intend on using it constantly.
    • Ifixoldjunk
      By Ifixoldjunk
      I had a bit of an idea for my 310-8. I’m thinking about making a weight bracket that kinda slides onto the factory wheel horse bagger mounts. Anyone ever do anything like this before? How much weight do you think the bagger mounts could hold? I probably wouldn’t put anything past 50lbs on it.
      Kinda like the modern craftsman weights they mount to the rears of the tractor. I’d figure it’ll help counter balance the blower in winter
    • whamm511
      By whamm511
      Can anyone tell me if 23 10.50 12 Wheel Weights will work on 23 9.50 12 wheels?
