Similar Content
By wh315-8
I have a question about the 69’ model. I took my tank out to work on carb easier. A couple weeks later as I put it back together & after cleaning everything; I replaced the white weatherstripping that was at bottom of tank and on the corners of the strap. Seems to be all that holds it in place. Because the strap around the tank will not go around the metal bracket on bottom and fit the tank. And even if it did the strap would only line up with the bracket mounting bolts which would be in the way. What did I miss? Didn’t pay close enough attention when I took it apart and can’t see in the parts diagram where the strap does go around the bracket. The weather stripping is tacky enough that the tank stays in place and it is a made to fit perfectly in position. Just seems that the metal strap is pointless.
By Evil Archer 300
Yesterday I filled the Rear wheels with RV Antifreeze, Got the wheel Weights on and mounted the plow. Today Grading the 1500 ft Driveway.
I'm impressed the new Eaton 1100 pushed like a bear. The Hydro lift is great. For the last 12 years I've been doing all the work here with the 310-8. Huge difference,
When I bought this Tractor it was in tough shape all rusty and no maintenance. After some sandblasting ,Paint and a new Hydro I love it
By Evil Archer 300
I recently purchased a 1988 518-H. When I check the Oil level on a cold motor it is very high, If I bump the ignition ( without starting ) it goes to the normal level. Any Ideas
By Evil Archer 300
New member here. Springwater NY I have owned my 310-8 for about 10 years, It's tough and very reliable.
Last weekend I bought the 518-H. When I got it home it didn't seem to have the ability to climb the hill in my back yard. About a 15 degree slope. I found out ( A little Late ) Wheel Horse used 2 different Transaxles in these. Apparently I got the Eaton 700.
Thru your sight and a very helpful Retired Wheel Horse dealer I changed the oil to a Synthetic. Seems 100% better.
I am looking to replace Transaxle with a Eaton 1100.No rush.
I do believe I got a great deal even with the 700 Tranny. Tractor with weights and chains, 48" side discharge ,42 Rear Discharge,48" Plow and a cart. $550
The Tractor needs some work and a Paint job, But it runs well and mows great.
Thanks for the help and keep up the good work
