cleat 6,688 #51 Posted March 1, 2014 Installed the foot rests, cover, and guards on the rear 520. Front 520 rear wheel in the tire changer showing protective tape on edge of rim. Rear tires assembled, leak checked, and installed on front 520. Cleat 2 Share this post Link to post Share on other sites
motox25 36 #52 Posted March 2, 2014 Wow that paint really looks nice, are your seats recoverable? Share this post Link to post Share on other sites
dodgemike 52 #53 Posted March 2, 2014 Cleat your work is amazing. My wife has the exact same Stang. Since your switching between rattle cans and guns please tell us what brand and color paint you are using. Thanks Sent from my SCH-S720C using Tapatalk 2 Share this post Link to post Share on other sites
cleat 6,688 #54 Posted March 2, 2014 I cut out a piece of rigid black plastic to make a steering wheel center cap. Before. After. Cleat 1 Share this post Link to post Share on other sites
cleat 6,688 #55 Posted March 2, 2014 Rattle can paint is Excel farm & implement paint. Harvester red. This paint came from TSC. Rattle can primer is Rustoleum red oxide. Spray paint, reducer, and primer is at my neighbours as he is in the process of painting the hoods and rear fenders so I will have to get back to you. This paint also came from TSC. Wheel rattle can paint is Rustoleum high performance wheel 257791 steel. This paint came from Home depot. Wheel rattle can primer is Rustoleum light grey. 1 Share this post Link to post Share on other sites
cleat 6,688 #56 Posted March 7, 2014 Rear 520 has it's front end pulled apart. Frontaxle before cleanup Front axle after cleanup, just needs paint. Spindles have been bead blasted and painted Front wheels have also been bead blasted and painted but still at work paint drying. Cleat Share this post Link to post Share on other sites
JERSEYHAWG / Glenn 4,498 #57 Posted March 8, 2014 Looking really good Cleat. Thanks for update and progress pictures. Glenn Share this post Link to post Share on other sites
cleat 6,688 #58 Posted March 8, 2014 Front wheels beadblasted and painted. Now to wait a couple of weeks for the paint to dry then remount the tires. Cleat Share this post Link to post Share on other sites
stevebo-(Moderator) 8,363 #59 Posted March 8, 2014 Slow and steady and work is coming out really nice!! Share this post Link to post Share on other sites
cleat 6,688 #60 Posted March 9, 2014 Cleaned up the tires for the rear 520 and inflated the rear tubes to check for leaks. Went and picked up 2 new seats as they were on sale. Cleat Share this post Link to post Share on other sites
AMC RULES 37,141 #61 Posted March 9, 2014 A great rubber rejuvenator, find it at your local Napa dealer. Share this post Link to post Share on other sites
cleat 6,688 #62 Posted March 9, 2014 Thank you for the info on the rejuvinator. I painted the front axle on the rear 520 today. Now to wait until the paint is all dry then resume assembling. Cleat Share this post Link to post Share on other sites
cleat 6,688 #63 Posted March 15, 2014 (edited) Front spindles installed with teflon washers to help steering effort. Rear wheels glass blasted and painted. All wheels painted and ready for tires once I feel paint is dry. New chrome plated lug nuts installed. All rear wheels will be installed this way. Cleat Edited March 15, 2014 by cleat 2 Share this post Link to post Share on other sites
Martin 2,133 #64 Posted March 15, 2014 looks nice Cleat. I've used the bolts and lug nuts on previous rebuilds and they are definitely a good choice over the oem lug bolts. I'm already getting frustrated pulling the wheels on and off my current build with the oem bolts. just wanted to keep them on this one for some reason. I'm enjoying the updates...... Share this post Link to post Share on other sites
cleat 6,688 #65 Posted March 15, 2014 (edited) Well, I deemed the front wheels paint dry enough and mounted the tires. Went well with no paint damage. Mounted on tractor, greased and installed plastic hubcaps. Rears will get mounted next week (I know that sounds bad). Cleat Edited March 15, 2014 by cleat 1 Share this post Link to post Share on other sites
cleat 6,688 #66 Posted March 16, 2014 For some reason the later model 520 did not have these belt guides installed. The tractor had the holes punched but never tapped for bolt threads. I tapped the holes and bought a set of guides from ebay. Guides are now installed and belt guard is reinstalled. Cleat 1 Share this post Link to post Share on other sites
cleat 6,688 #67 Posted March 16, 2014 I installed the rear tires and rims on the rear 520. Both machines lined up just waiting for the hoods and fenders to come home from being painted to finish assembly. Cleat 1 Share this post Link to post Share on other sites
HorseFixer 2,012 #68 Posted March 16, 2014 Lookin like a couple of nice horses! ~Duke Share this post Link to post Share on other sites
Ken B 3,164 #69 Posted March 18, 2014 Nice work Cleat. Where did you get the seats? The TSC near me used to carry nice seats like yours, now they carry real cheesie looking ones.. Share this post Link to post Share on other sites
cleat 6,688 #70 Posted March 18, 2014 I bought mine at Princess Auto which is about an hour away because of price. TSC that is just down the road from me carries them as well but they cost more there. Mounting pattern is not just right but drilling a hole in the slides worked. Wheel horse mounting pattern is 7.5 wide x 8" deep. These seats are 7.5 wide x 7" deep. The only other issue is the Wheel horse arm rests do not bolt up to these seats. They sell an arm rest kit for these seats but they cost more than the seat. Thanks, Cleat Share this post Link to post Share on other sites
Aussie 98 #71 Posted March 21, 2014 very nice work Cleat, inspires me to get moving with mine I think the reason the later one doesn't have the belt guides is that the drive belt is always under tension from the idler pulley whereas the early belt can flap around a lot more when the idler pulley is disengaged. Doesn't hurt to have them there though. Share this post Link to post Share on other sites
cleat 6,688 #72 Posted March 21, 2014 That could be. I removed the disengage mechanism from the early one because I never use it and it seemed to rattle all the time. Cleat Share this post Link to post Share on other sites
Aussie 98 #73 Posted March 21, 2014 That's a great idea! D'oh - I hadn't thought of it, but will do the same. I think the disengage may have been to take the load off the engine for starting, but obviously wasn't needed as they did away with it. Mine jumps around like mad. thanks kym Share this post Link to post Share on other sites
Hendricksn 7 #74 Posted March 22, 2014 Where'd you get the plastic grease caps? And you said tsc carries those seats? Share this post Link to post Share on other sites
cleat 6,688 #75 Posted March 22, 2014 Plastic grease caps came from ebay. A couple different people seem to have them there. They are not as high quality as the originals. My original ones had the center cut out by improper cotter key installation by previous owner. TSC in Canada carries these seats. Cleat Share this post Link to post Share on other sites
