Ed Kennell 39,398 #1 Posted January 28, 2014 Some of you may remember the pair of solid 16 X 4 B F Goodrich Silvertown tri-ribs I bought at an auction for a buck last fall. I had a pair of rims on an old lawn cart that I cut apart to make the split rims, then mounted them on the C-101. No more flats and they weigh 18 lbs. each. 4 Share this post Link to post Share on other sites
jwl 75 #2 Posted January 28, 2014 I have those same kind of tires, mounted on factory two piece rims, on the sulky for my Pond walker. The only thing I see different is the tread pattern. 1 Share this post Link to post Share on other sites
smoreau 658 #3 Posted January 28, 2014 cool no more flats Share this post Link to post Share on other sites
C-85 709 #5 Posted January 28, 2014 I'm wondering if you really needed to split the rims to do this. When I was a Toro dealer in the 60's, we used to replace the solid tires on the self propelled mowers by boiling the tires and then mounting them on their wheels. I know the Toro tires were smaller than these, but it worked for us. Even after boiling the tires, they still were pretty hard to install on the wheels. Share this post Link to post Share on other sites
Jake Kuhn 1,561 #6 Posted January 28, 2014 Very cool! Share this post Link to post Share on other sites
AMC RULES 37,143 #7 Posted January 28, 2014 Yeah...with built in weights too. Share this post Link to post Share on other sites
Ed Kennell 39,398 #8 Posted January 28, 2014 I'm wondering if you really needed to split the rims to do this. When I was a Toro dealer in the 60's, we used to replace the solid tires on the self propelled mowers by boiling the tires and then mounting them on their wheels. I know the Toro tires were smaller than these, but it worked for us. Even after boiling the tires, they still were pretty hard to install on the wheels. Don't think boiling would have worked in this case C-85. These tires are really hard and laced with cording. I had to grind away the ridges on the ID of the tires just to get them started on the split rims. Thanks for the tip though.... It may work on smaller tires. Share this post Link to post Share on other sites
Sparky-(Admin) 21,586 #9 Posted January 28, 2014 Very nice job! Mike......... Share this post Link to post Share on other sites
dodgemike 52 #10 Posted January 29, 2014 Very nice tractor. Sent from my SCH-S720C using Tapatalk 2 Share this post Link to post Share on other sites
