zanepetty
how to run throttle and choke cables
zanepetty
Does anyone have any good pictures of where the throttle and choke cable goes on my 753? I'm thinking one runs over the head and the other goes under the engine shround but I can't remember for sure. Any pics or help is appreciated. Also does the little hooked spring on the govenor arm go through the notch on this disc? Thanks in advance.
post-11334-0-18616700-1390328177_thumb.j
Edited by zanepetty
AMC RULES
Have you down loaded your engine manual Zane?
Lots of detailed info in there that will help you.   :handgestures-thumbsup:
zanepetty
Yes I have that but the images are a little different and I don't remember the throttle cable booking up to the disc..maybe I just don't remember it but I think both cables went to the carb and I don't really remember where the cables were routed. And I don't have the the piece with the throttle bracket on it..is there an alternate way of booking up the cables?
Edited by zanepetty
zanepetty
Thanks a bunch for that. So do I need the throttle bracket? It doesn't seem like it does anything?
chazm
Not sure what you mean by "throttle bracket "   :confusion-shrug:
There is a bracket that secures the end of the throttle cable housing / the throttle cable "wire end" connects to the gov arm / there is a solid rod going from the top of the gov arm to the carb linkage :handgestures-salute:
zanepetty
That's just what they called it in the manual it goes on the shaft behind the disc..
zanepetty
OK I've figured out I do need it. Anyone know where I could get one?
chazm
OK Zane, I look at my k181 manual and YES,  you will need that "throttle bracket"   /   On pg 17  figure 5-4 & 5-5 shows how it is connected & how to adj once connected :handgestures-thumbupright:
I do not see that bracket in your pic above.   :confusion-shrug:   I hope you didn't misplace it :eusa-think:
zanepetty
OK I have the bracket. I would appreciate that so much :) that would b a great help
TT
Try this:
zanepetty
That helps. I actually saw that b4 but I just wanted to k ow exactly where the cables go and what goes on the end of that tab.
TT
Did you see these pics?:
zanepetty
That's what I needed. Thanks so much. This site and you guys are the best.
  • Similar Content
    • Donavon1
      By Donavon1
      Project black Betty the diesel 1054
    • bigbuck
      By bigbuck
      I had a fire in 2019 which destroyed my pole barns and some wheel horse tractors and parts. i'm looking for someone who can use the engine that went thru the fire. It is not pristine but there must be some usable parts
      please call George at 517-499-5678 for more info.
    • cJ_3D
      By cJ_3D
      Hey all!
      Replacing the drive belt on my 252-h. Anyone know the torque specification for the center screw when I put this pto clutch back on? I know it was on there tight it took a minute for the impact to break it loose. Thanks!
      CJ
    • bkarp@roadrunner.com
      By bkarp@roadrunner.com
      my magnum 12 kohler all of a sudden is blowing oil out of the carb. if rings are bad should oil be blowing out of the muffler.thanks for any help brent
    • Tinman1962
      By Tinman1962
      Recently got hold of a 656 it's has a "newer" 61/2 Briggs on it I don't believe that's right any ideas about that
