Countdown To Christmas!
Jparkes43
To straight pipe or not to straight pipe
Jparkes43
Hello on my kawasaki 227-5 17 hp single cylinder i was thinking about putting a straight through pipe on it and people time and time again were mentioning burnt or warped exhaust valves and i have no idea how bad this is or how common it is so i just want to know if i should or shouldn't straight pipe the engine
thank you
James
see my other thread about tachometer gauges
Edited by Jparkes43
meadowfield
James, not something I've looked into...
Welcome to red square, come and say hello in the euro section!
Mark
Sparky
Is this a pulling or racing tractor? If so then go for it. But if you plan on mowing and doing yard chores with it I think you'll find the straight pipe to loud and annoying. Do you have neighbors?
:WRS:
Mike.............
Jparkes43
Thank you for the welcome I was planning to take it racing and not really for garden driving, I was going to make the pipe long so it wasn't too loud but I thought it would help power
Thank you for replying
James
Stormin
With a straight through on a petrol engine you could lose a bit of power. Petrol's need some back pressure.
Jparkes43
ok thank you all for the replies, I'm just thinking of putting a cutout in the manifold so it can be quite and then on demand or if i want more power i could use a cut out
  • Similar Content
    • Gcw804
      By Gcw804
      I have a WH 300 series with a Kohler Magnum 10 engine and I cannot for the life of me figure out how to get the choke cable and linkage set so it will work. The numbers on the engine label  are worn off the, so I cannot give anyone that information. Does anyone have a picture or can you head me in the right direction.
      My arm for the linkage assembly is set at 3 o'clock and 9 o'clock if that helps. There seems to be several different linkage rods for this engine.
      Thanks
      Gary Williams
    • tractorboy79
      By tractorboy79
    • BuffaloD200
      By BuffaloD200
      '74 D-180
      My friction disc in gone on my clutch.  I saw the old post about making a new friction disc, so I'm not concerned about that.
      I managed to remove the front clutch plate and double v-belt pulley.  But I can't separate the two.  When I took the assembly off the spiraloc washer popped off on its own.  I HAVE READ THE MANUALS.
      So I should be able to just remove the pulley from the front clutch and continue with step 4.  The v-belt pulley is loose as all hell and flops around like a dead fish.  It seems to be hung up on a ring or bearing race.
      So my thoughts are grab a BFH or sparky the blue tip wrench.
      Is there an unpublished step 3.5, or some trick?
    • BuffaloD200
      By BuffaloD200
      Hey all,
      My '74 D180 has a lot of trouble pushing snow.  Weighted tires, but nothing else at this time.  I've found it gets stuck frequently and only one wheel spins.  Do these tractors not have a limited slip/locker arrangement?  How does everyone manage with the infamous one wheel peel?
    • Donavon1
      By Donavon1
      Project black Betty the diesel 1054
