oaktown1987
B112
oaktown1987
Can anyone tell what the carb number on a b112 wheel horse
Sent from my iPhone using Tapatalk
boovuc
A 1980 or 1981 B112 vertical shaft Briggs doesn't show the carburetor or a carb diagram on the Toro or parts tree site. The Briggs parts homepage doesn't list the "Type" spec for the two spec numbers that Wheelhorse used in the B-112. (Your engine model is 252707. Your "Type" numbers on the 1980 is 0222-01 and the 1981 "Type" was 0206-01).
We'll see if any of the other motor gurus can lend a hand in your search. That 11 HP Briggs was used on a lot of the LT series and the A series WH tractors so you may want to ask our membership for those who have them to take a peek at one of them for some numbers off their carbs.
Desko
I'd say go to repair clinic and type in you model number and code number off your motor and you should find every part for the motor. :)
boovuc
Desko knows his sh#%!
Use the Briggs model number and the TYPE number, (either one), and go to Repairclinic.com and see if that helps your cause!
Desko
Yea its a good website to keep the old and new motors running Joe's is also a good place to find old parts if you don't want to spend a fortune. Also lets see some :banana-gotpics: of this old iron.
oaktown1987
joes?
chazm
joes?
Joe's Outdoor Power, - look in vender section
