Kelly 1,030 #26 Posted May 4, 2008 Ok to answer a few questions and comments. I love them all guys keep them coming it helps fuel the need to work on it. I planed on stainless head bolts, but yes accorn would look good, the flathead style is what I'm going for, kinda a 32roadster look with out the cost . I never thought of wiring the lights like that but making them not grounded to the mount will be hard, I thought about getting diff. bulbs, if that don't work a resistor will. I wanted to make the mount for the lights follow the hood lines and the upswept look of the axle, I need to make stops for the axle so it don't pivot up and take out a light. As for the blower shroud on the head, I'm leaving it off, to show off the head. I don't think it will over heat, because it will not be worked like normal, just to drive around shows. As for the fenders I tossed the idea around, about putting motorcycle fenders on it, the old chrome ones, but decided not to, it will be fenderless. I'm thinking about building my front wheels, More on that later Share this post Link to post Share on other sites
linen beige 14 #27 Posted May 5, 2008 Kelly; Thinking about the scoop, it would add too much height to the front and spoil the lines wouldn't it. I think the resistor in line with the tailights is the way to go. if you drop them down to 5 or 5 1/2 volts the bulbs will be a tad dimmer but will last forever. On the wheels, I think she' screaming for some "Moons" and a set of Wheel horse logo hubcaps would fit the bill. Keep up the great work. :whistle: Share this post Link to post Share on other sites
perry 82 #28 Posted May 9, 2008 I have a bigger pulley but that will mess up the stock belt guard, and stock belt size, and I don't want to cut up the 1055 guard it's my only spare. man these post move fast anymore . thats looking sweet. . lights, and your spindles are for speed dont you put a smaller pulley and the trans and a larger one on the engine . i know that raider 10 i had flew and that had about a 3" pulley on the rear. Share this post Link to post Share on other sites
linen beige 14 #29 Posted May 22, 2008 Kelly, How's the little beast comin' along? I spotted some 4.80x4x8 tires with 2 1/4 inch whitewalls over on the Coker tire site that would make her look awful "1950s". But they are NOT cheap! They're made for the Cushman scooters. Share this post Link to post Share on other sites
Kelly 1,030 #30 Posted May 30, 2008 Mini update on the tractor, picked up a pair of 24x12x12's and mounted them on 8.5 rims off a parts 520 I have, I had 10.5's on it, I like the big tires one pic is with the 10.5" on one side and the 12" on the other. I'll get pic's of them both mounted up. Share this post Link to post Share on other sites
Sparky-(Admin) 21,510 #31 Posted May 30, 2008 Go with the wider tires . Way cool. Mike.......... Share this post Link to post Share on other sites
Rollerman 290 #32 Posted May 30, 2008 I like the wide tires too Kelly. :whistle: Share this post Link to post Share on other sites
Confused99 2 #33 Posted May 30, 2008 Another vote for the bigger tires. That looks sweet. Jason Share this post Link to post Share on other sites
linen beige 14 #34 Posted May 30, 2008 WIDER TIRES! WIDER TIRES! WIDER TIRES! Can we vote twice? Share this post Link to post Share on other sites
Kelly 1,030 #35 Posted September 7, 2008 It's been a while, been busy with other stuff, so this got put on the back burner,Here is were I'm at, The motor is a fresh 16HP kohler still yet to start it, I'm going to tear the tractor apart again and repaint it this winter, I hope it was blasted and spray bombed to get a idea of the final look, I need to change, a few things, the motor needs to move forward 1/4" I mocked it up with a 10hp from a 1055 then built the 16hp and put the tin from a 1067 on it with the S/G (thanks Perry for the tin and brackets) but then I found out the tin and flywheel are smaller on the 1055 motor's so I had to off set the motor to the left of the tractor so the bearing plate and flywheel could hang off the frame, I used the 1055 oil pan, I learned alot that night about all the, diff. pieces on the 1055/1045/1075 motors, this is mostly WH parts but does have rupp mini bike front wheels, and a cub steering wheel, and the motor was orig. a cub motor, the rear center caps are from a semi, they are the center caps from the wheels, they don't fit too bad and the muffler is a Harley pipe, not yet hooked up, and I need one new rear tire as you can see one is shot. anyway here it is In the beging and now Share this post Link to post Share on other sites
BairleaFarm 340 #36 Posted September 7, 2008 Sweet Looking. I cant believe how good it looks. GREAT Job Kelly. 1 Share this post Link to post Share on other sites
Sparky-(Admin) 21,510 #37 Posted September 7, 2008 Verry cool Kelly. Are you gonna swap out the pulleys to get more ground speed? Mike......... Share this post Link to post Share on other sites
sorekiwi 761 #38 Posted September 7, 2008 Awesome, Kelly :omg: Share this post Link to post Share on other sites
Kelly 1,030 #39 Posted September 7, 2008 Yes Mike I'm going put a smaller rear pulley, but not to small :banghead: Share this post Link to post Share on other sites
big mike 13 #40 Posted September 7, 2008 That thing is Boss, Daddyo! :banghead: Share this post Link to post Share on other sites
kpinnc 12,757 #41 Posted September 7, 2008 Looks great Kelly! Kevin Share this post Link to post Share on other sites
DOC in Kentucky 178 #42 Posted September 7, 2008 WOW !!!! I am thinkin if Herman Munster had a Wheel Horse, this could of been his. I am not sure why Herman Munster came into my mind though Musta been some kinda of late 60's, early 70's flashback Kelly, it is way cool :omg: Share this post Link to post Share on other sites
JosephC 0 #43 Posted September 7, 2008 :USA: Your creation is real cool!!!! With the look that you are going with might I suggest using a Real 2 ball,a large red dice,or a piston for a shift knob. I like the BIGS an Littles look. :banghead: Share this post Link to post Share on other sites
bell 11 #44 Posted September 7, 2008 WOW! NICE WORK!!! :banghead: Share this post Link to post Share on other sites
linen beige 14 #45 Posted September 7, 2008 Absolutely perfect! Especially that transparent exhaust manifold! Where'dyagetitIwantone? :omg: Share this post Link to post Share on other sites
traktorkidd7/30/93 1 #46 Posted September 7, 2008 Mike (Sparky), You read my mind. And that looks fantastic :horseplay: :horseplay: Share this post Link to post Share on other sites
Stigian 1,234 #47 Posted September 7, 2008 Lost for words................... Almost That's some very nice work Kelly Loving the width of those rear tires, and those cool little tail lights :omg: Share this post Link to post Share on other sites
perry 82 #48 Posted September 7, 2008 :USA: looks pretty sweet kelly i need to stop out there before this damn summer is over...... , Share this post Link to post Share on other sites
Teddy da Bear 11 #49 Posted September 7, 2008 Loving the width of those rear tires, and those cool little tail lightsHmmmm......those look like the tail lights that Burly and I have been looking for our 1054A's..... And it looks like he has two!!! Sincerely....that is one professional job. :banghead: Share this post Link to post Share on other sites
Duff 206 #50 Posted September 7, 2008 Man, Kelly, that is one happenin' tractor! NICE work! Duff :banghead: Share this post Link to post Share on other sites
