bill moore
Needle bearing for 1964 1045
bill moore
I am trying to find a needle bearing for my gear box. In the Manual it is listed as #4 and the part number is 1532.....Can it be cross-referenced or perhaps someone has more info...?
chazm
Did you check the cross reference post :eusa-think:
Actonhorse
I just ordered a 1532 from my Toro dealer.  Napa tried to find it using all of the cross reference numbers and couldn't so I had no choice but it was still available, just pricey.
bill moore
Actionhorse, The Toropeople down here say it isn,t  available...do you have any other numbers for tha bearing...?
chazm
In the Cross ref link I post above has the cross over to
# 1532
Torrington # M-­â€16121
MOTION IND  #00090903
Hopes this helps  :handgestures-thumbupright:
Actonhorse
I tried the Torrington number at Napa and they couldn't find one but that doesn't mean that they aren't available.  The dealer had it in stock...
Dean
bill moore
...I found an M 16121 at Blair Bearings here in Miami...It has a grease fitting but all else is the same...Installed last evening...on to the next puzzle....Thanks to all above for help and information...
         Bill.
