Agage1 83 #1 Posted January 9, 2014 The drain plug on an old 857 worker I have is pretty rounded over and giving me a hard time. Before I drill it out I was thinking it might be easier to leave it in and drill and tap a new plug. What do y'all think? Share this post Link to post Share on other sites
can whlvr 993 #2 Posted January 9, 2014 before you drill it try a large easy out,it might grab enough in the allen hole to get it out,if not then drill it and then use an easy out,it should turn,just be careful to not break the easy out,they are hard to drill Share this post Link to post Share on other sites
953 nut 55,856 #3 Posted January 10, 2014 Get out the side grinder and grind it square to the size of a wrench you own, should work. Share this post Link to post Share on other sites
TT-(Moderator) 1,145 #4 Posted January 10, 2014 Read this first: Share this post Link to post Share on other sites
Agage1 83 #5 Posted January 10, 2014 Thanks TT between welding on a nut or the torx bit I'm sure I will get it out with out too much trouble. Share this post Link to post Share on other sites
