Agage1
drain plug
Agage1
The drain plug on an old 857 worker I have is pretty rounded over and giving me a hard time. Before I drill it out I was thinking it might be easier to leave it in and drill and tap a new plug. What do y'all think?
can whlvr
before you drill it try a large easy out,it might grab enough in the allen hole to get it out,if not then drill it and then use an easy out,it should turn,just be careful to not break the easy out,they are hard to drill
953 nut
:twocents-twocents:  Get out the side grinder and grind it square to the size of a wrench you own, should work.
TT
Read this first:
Agage1
Thanks TT between welding on a nut or the torx bit I'm sure I will get it out with out too much trouble.
