Steve in Mo 3 #1 Posted September 5, 2008 I have a K214AS 10Hp engine. The coil went bad (looked to be original) purchased a new 12volt coil with externial condensor from Car Quest. Unit ran total of 2 hours or so. Now no spark again, do I really need a Kohler coil and should I just get internial condensor (resitor) ???? Both the Wheel Horse site and the Garden Tractor fourm on Antique Tractors.com say I should only use Kohler parts but I can't see how it makes a difference. Share this post Link to post Share on other sites
big mike 13 #2 Posted September 5, 2008 I would get an internal resistor coil and let'r fly.I don't see how the brand(Kohler or CarQuest) can make a difference. Share this post Link to post Share on other sites
rocking 416 1 #3 Posted September 5, 2008 you also mite want to check point gap .. a kohler coil is under 40$ last time i bought one with new mount too Share this post Link to post Share on other sites
oldandred 15 #4 Posted September 6, 2008 Every once in a wile I go to the local junk yard for autos they charge a dollar to get in and I look for coils in cars with the older ing, systems I get about four or five + other stuff the most they charge is $1.00 for the coils and have been using them for years with out any problems :banghead: Share this post Link to post Share on other sites
BairleaFarm 340 #5 Posted September 6, 2008 Every once in a wile I go to the local junk yard for autos they charge a dollar to get in and I look for coils in cars with the older ing, systems I get about four or five + other stuff the most they charge is $1.00 for the coils and have been using them for years with out any problems thats actually a great Idea Share this post Link to post Share on other sites
Kelly 1,029 #6 Posted September 6, 2008 If using a car coil, make sure you put a ballast resistor on it to drop the voltage down to around 9V, running 12V to the points all the time will burn the points, even on cars, they had a means to drop the volts after start up, resistor wire or ballast resistor, they only had 12V during start up to help with cold starts. Kohler coils have the resistor built in. Share this post Link to post Share on other sites
WheelHorse_of_course 99 #7 Posted September 7, 2008 :thumbs: A few points (pun intended??) 1) Not sure what you meant by an external condenser? 2) Some coils have an "internal resistor" and others require an external resistor. You can tell the difference with an ohm meter 3) If you don't have a resistor (internal or external) you will burn up points. 4) You might check your points before you buy another coil I would not buy a Kohler coil, I would go the third party or used route. Best of luck :omg: Share this post Link to post Share on other sites
