Slimpickins
Sunstrand id of models it came
Slimpickins
Hi there my son and I have been bitten by the horse bug and started to collect some things . We received a sunstrand trans Id number 90-2001. We would like to more about it as what models it came in . But every link I have followed comes up with nothing.Any info would be great. Oh and by the way this is a great site and we have learned a lot of get stuff from you all thanks alot
stevasaurus
I have seen no list for the Sundstrand transmissions and which horses they were in.  I went into manuals and found a Sunstrand transmission manual.  It hints at some "D" series and a few others.  Unless some of the members come in here and say they have a Sundstrand on there horse, I do not know how you would get that list.  You could look at this manual and then pull up manuals of the hydro horses for that time frame and see (all on this site), but it would take some computer time...they are all hyrdos.  :)
Slimpickins
Thanks Stevasaurus for trying . I was thinking that I mite try to rebuild for a spare for 73 16 auto if I can find parts numbers for it.
JimmyJam
Are you certain the Sundtrand is off a Wheel Horse? I have a 1968 Electro 12 with a Sundtrand, but the ID # is 90-2046. In reviewing all Wheel Horse models that used Sundtrand I don't see # 90-2001.
I stand corrected! I found that a 1966 1076 offered several transmission models, one of them being a Sundtrand 90-2001. Unfortunately due to problems with the rear tow valve they had different replacements. Parts, I was told are no longer available. Sorry!
Edited by JimmyJam
JimmyJam
Your 1973 16 Automatic took a Sundtrand #90-2046. Same as mine in a 1968 Electro 12. What parts are looking to rebuild on yours? I may have some extra parts for that Sundtrand floating around!
Edited by JimmyJam
TT
I'm thinking that's one of the earliest pumps used on the '65, '66, early '67 models with the rear-mounted tow valve - when the entire transaxle assembly was identified by a single WH part number.
Perhaps an owner of an 875/1075/876/1076/1276/877/1077/1277 can verify ~ since all of that info I had saved left my possession two (dead) computers ago.
953 nut
:WRS:   The number you have may or may not be for a :wh: . The best bet would be to post a photo so we can take a look. In the lower right corner of the reply page is a button for "More Reply Options", click on it and attach a photo.  :wwp:   :text-welcomeconfetti:
Slimpickins
Thank you everyone for replying .jimmyjam the 16 auto trans is good for now I just wanted a spare.Here are some pics and thanks all for the help. PS it looks like the one in my 875 but have not seen the tag on that yet do to cold. Thanks again
post-12310-0-69314500-1388876672_thumb.j
post-12310-0-74512400-1388877172_thumb.j
post-12310-0-77058300-1388877225_thumb.j
Edited by Slimpickins
953 nut
:text-coolphotos:   The Sundstrand trans. on :wh:  from 1965 to 1967 was # 3100077, from 1968 to 1971 was 90-2046 except the GT-14 which was a 90-2062. The pumps are prety much the same and your pump may have been exchanged from another brand of GT that also used Sundstrand pumps. I agree with you that it looks like first generation; '65 to '67 :wh: .
bobpope
I have a model 1075 wheelhorse that I believe was built in 1965. it has the sundstrand model 902001 on the hydro transmission plate under the seat.
  • Similar Content
    • giant_g2
      By giant_g2
      Not sure on specific model. This 8 spd came attached to a plow I bought. It had some water in it for a couple weeks according to the prior owner. I drained it, sloshed some diesel in it, drained that, then filled with fresh oil. Spinning the input shaft by hand, I can see the axels turn. Hasn't leaked any oil. I'm not really interested in shipping, so I'd prefer local sales.
    • Doug B
      By Doug B
      Hey guys,I have a dilemma I need some help with. I have a 1969 GT 14 that I replaced the transmission and pump on. For about 2 weeks afterward everything worked great, but while mowing at a pretty good pace I noticed a shudder and the tractor slowed a little but not bad. The more I rode it the slower it got until it barely moves. What stumps me is the hydraulics are still very strong,as in I can back the 3 point under the bumper of my truck and if you lift the arms all the way up the front wheels of the tractor will clear the ground. Have checked the tow valve and checked the internal filter,but no luck. I have also checked and replaced the forward and reverse bypass springs and the lever is moving the cam to full travel, forward and reverse. Any help would be appreciated.
    • mattd860
      By mattd860
      I have developed a kit that allows a Wheel Horse / Toro hydrostatic tractor to be operated by a pedal on the right side of the tractor. The original forward/reverse lever can be retained or removed. The kit includes everything needed to install the pedal kit and installation is simple with the help of a downloadable installation manual. Additionally, only one (1) 1/4" hole will need to be drilled which can be done by a hand drill. No other drilling or cutting will be necessary. Any tractor with this kit can be converted back to stock without any visible evidence that kit was installed. However, you'll never want to do that
      The foot pedal is custom cast in Aluminum, uses brass bushings to minimize wear, and it closely matches the OEM Wheel Horse BRAKE pedal commonly found on 8-speed manual transmission tractors. Modifications were done to the pedal to add the reverse pedal and adapt the pedal to the rest of the kit. For the most part, the pedal looks like it was designed and manufactured by Wheel Horse / Toro. Additionally, a grease fitting has been adapted to the pedal to further minimize wear and tear and if the brass bushings ever wear out they are fully replaceable without having to buy a whole new pedal.
      Here is a link where you can download the installation manual: CLICK HERE
      I am selling these kits for $330 shipped to anywhere in the United States. I offer multi order discounts as well. I will also sell to other countries for additional shipping charges to be determined.
      Thanks!
    • Dylan2342
      By Dylan2342
      New here! hello everyone! In a bit of a pickle here. My father owns a 1993 (I think that is the right year) 520H Wheel Horse. I don't commonly work on tractors but it seemed simple enough. the axle snapped on the left side, so it needed a new transmission. My dad bought a used transmission and I went to work changing everything out. The hydraulic pump that the engine's drive belt attaches to went to a different model/year of tractor, so I had to remove that part and swap it in from the old transmission. In the process I lost all of the oil in the pump (I mention this because I wonder if it has to do with my problem I'm having). When I reassembled everything I started the slow process of filling the transmission. I filled it up and started the engine. When moving the lever forward or backward, it had a tiny bit of power for a little bit and then lost power. The transmission wasn't doing anything, anymore. I though maybe that hydraulic pump needed to be primed, so we took the top hydraulic line off of the hydraulic pump right above the drive belt and used a transfer pump to pump some oil into the pump case. This still didn't work. I don't have enough experience with these hydrostatic transmissions to know if we got a bad transmission or if there is something obvious that I am missing when it comes to a transmission swap. I ask for any insight and help please. If you need pictures or any other info, then let me know what you need. Thank you!
    • Porkskin
      By Porkskin
      I have no understanding of what it is like to push one of these when the trans is disengaged and motion lever is in the forward position as the manual mentions. I hope this is not old ground and that I am not cross posting. With the trans disengaged and motion lever set forward there is still something spinning in and about the transaxle that is giving resistance. I need to know if this is normal or if I should be expecting more of a free wheeling experience. In effect, much less resistance. Thank you for comments or pointing me to a topic that already covers this.
