HorseWhisperer
Will tins and S/G from 953 engine fit on 73 K301 block?
HorseWhisperer
I want to refit my 953 with a fresh K301 but I want to retain the reliability and look of the starter/generator.Will the tins and all go on the 12 hp motor?
TT
That's a question that's hard to answer without knowing more about the 301.
I am in the process of doing something similar with a 241 from a 1067 and a late 70's 301.
It's a lot more involved than just swapping out the tins and adding the S/G.
Get the flywheels off both engines and measure the length of the crankshaft from the bearing plate to the end of the taper.
If the 241 crank snout is longer than the 301 crank snout then you have some work to do.
HorseWhisperer
Didn't give that a thought Terry.It's all in that finding.I was under the impression them big blocks had the same gear inside.I gave the flywheel some thought but never the crank dimension!Lemme know how you make out as I am in the planning stages a couple weeks out!
TT
I got through all of the different crank snout / bearing plate modification / remove ring gear from newer flywheel stuff on mine already. I just need to finishing putting it together and get it on the tractor. It's not high-priority and the shop is cold, so that might be a spring project. :eusa-whistle:
HorseWhisperer
Alright Terry,I just got my hands on a rode hard and put away wet 1055.It trash but the engine is all there and runs well.I also have a fresh rebuilt K321 cradle motor at my disposal,love to bolt that shallow pan on it w/ starter gen and stuff it in a commando chassis!
Kelly
The 1055 uses the small flywheel and the matching small bearing plate, you will have to swap both, and the shallow pan on the 1055 will fit the small base blocks but you will have to cut the dipper on the bottom of the connecting rod to the correct size.
  Back to the flywheel and bearing plate, they are smaller on the 1055 engine because the bearing plate and blower tin tin sit over the frame on that tractor, and with the shallow pan they would hit if not smaller, and on a side note you will have to swap the clutch cross shaft, trans pulley and belt guard from the 1055 to make it all work, also the tab from the frame to the belt guard will need a little work to fit correctly.
HorseWhisperer
So the only real mod and not swap is the dipper?Have you done this Kelly?And by small base blocks are you referring to cradle motors?
TT
Kelly has a more-recent post on here somewhere with better pictures of the blocks but I can't find it. (I think I remember a cut finger....  :scratchead:)
I did find this one from a while ago:
The earless blocks were used on the iso-mount Wheel Horses.
HorseWhisperer
Ok,I got it!The earless blocks are the iso mounts or I call em cradle motors.That's good news then.!!You kids are the best!
Kelly
Yes I had a boo boo on my finger in one pic, I can't find the post, it was in reply to another engine swap, I may have to start a thread with pics, maybe get it pinned to show the block and pan styles.
