Rayp
Hi, I'm Ray from Cheltenham England
Anglo Traction
Ray,
       I'm pleased that your now able to post Pics. :hide: It was not intended by me to force your arm up your back to become a Supporter ! (maybe I should sell Insurance! :D ), but more than pleased that you have turned Red  :eusa-clap: .
It may be worth checking to see if you have adjustable settings for Pic size on your camera etc. I have set mine to E-mail size, which produces pics of about 850kbs. Reasonable image, but the site dumbs them down in the post anyway to about 300kbs......check it out.
Seat has had a hard life, but original,  keep it if you can.
Regards.
Wheel-N-It
Thank you for becoming a Supporter Ray!
Jparkes43
Hello nice to see a fellow englishman here
James
  • Similar Content
    • Deer hunter
      By Deer hunter
      Does anyone know where I could find a complete engine rebuild kit from for the k-19 ? I absolutely love my c-195 and have had it for years. But the motor let go last fall and I want to rebuild it or upgrade the motor, any suggestions?
    • davidfindlay
      By davidfindlay
      Looking to find a new home for my 84 (I think) C-145. It has a dump trailer with the enclosure for leaves, the PTO impeller to get the leafs into the trailer, the hoses for deck-to-impeller, impeller-to-trailer.
      I haven’t run it in over a year.
      The battery and the cable to the battery probably need to be replaced.
      Comes with a new head gasket still in the bag.
      Seat is cracked but still comfortable.
      Happy to answer questions or take other pictures.
    • BrianStasC-101
      By BrianStasC-101
    • HumbleHans
      By HumbleHans
      Operator manual 810343R1
      Wiring
      34 pages 17.5MB
      Wiring Colored
      1 page 228KB
    • t_furl43
      By t_furl43
      1979 c-101 nice project tractor just needs a few odds and ends, steering wheel, coil, carburetor bowl, the wiring was redone by previous owner....all 4 tires are good and hold air it goes into all gears no problem, transmission fluid has been changed, 10hp Kohler, message me or call or txt with any questions, it does run and runs well,  it’s been kept inside since I’ve had it, I would also trade for a mid mount grader blade thanks
