charging10
suburban 5010 transmisson
charging10
does anyone happen to know the oil capacity for a suburban 5010 transmisson?      thanks
AMC RULES
Manual call for 3 pints, SAE 90 wt gear lube.
stevasaurus
It will take somewhere between 1 and 1 1/2 qts of 90wt.  There is a check plug on one of the side plates near the back axle (I think on the left side).  Take off the seat and fender pan, fill through one of those bolt holes until the oil starts to come out the check plug hole.  That is the proper level.  :)
There is no drain plug on the bottom of the transmission.  Just take out one of the bottom bolts holding the plate to the casting and jack up the tractor to aid in draining toward the bolt hole.
Edited by stevasaurus
