rustyoldjunk
Toro master parts viewer is finicky
rustyoldjunk
OK someone tell me again how to put my model numbers into the Toro master parts viewer. I should know by now,i have used it several times over the years but if i don't use it over time i forget how the finicky viewer wants the numbers. I just ran the numbers on a 97 520 a few days ago and it went right thru but its more finicky with the older model numbers. The first of the two that i am trying to run now is model 1 0310 6 and serial 811718 ( Raider 12 ). The second is model T 1077 serial 291906 ( 1077 ).
TT
Enter "1-0310" for the first one and "1277" for the other. (1077 isn't recognized at the MPV)
Serial numbers aren't needed.
rustyoldjunk
Thanks Terry.
gwest_ca
They missed the 1077 but you can get what's left of it by using 1277. They shared a manual.
Garry
Adding
You can search the manuals in Red Square for 1-0310 and come up with the original 1971 illustrated parts list for many 1971 models. What is interesting is the index has a page that explains how they came up with the code letters to identify the different tractor models in the ipl. Always wondered how they did that. Here is a link to the manual.
rustyoldjunk
Thank you Garry,I will check the manuals out here.
