kudzu3 323 #1 Posted December 17, 2013 Where do I find new throttle and choke cables, and the filter in the bottom of the gas tank (where the line comes out), for B 80? How can I make my gas tank look new? Also, I have a bag of 100, (I only need two) 1/4 " ball bearings (balls) for shifting fork if anyone needs some. They were difficult for me to find, if you need 'um and can't find 'um, let me know. Thanks! Share this post Link to post Share on other sites
KATO 115 #2 Posted December 17, 2013 Im gonna assume its a 1-0140 1974 model if its not just type your model number into this page where it says CHANGE to bring up other manuals .you should find your part number here on one of these pages. http://www.toro.com/en-ca/parts/Pages/PartsDetails.aspx?mybeid=499&serialNumber=None&modelNumber=1-0140&searchTerm=9lzIRv+p5zdfEQshHJ6hwTGWTm7LESuR9KlPnfBg1Ot3FaOnBwSKFYgdsuwj9qUs#toro-parts-lookup-tabs for example your choke cable assembly number would be 101837 and heres a link to price http://www.jackssmallengines.com/searchresults.cfm?cx=008737122150761418589:c24nnqwh7co&cof=FORID:11&q=101837 Share this post Link to post Share on other sites
rmaynard 15,718 #3 Posted December 17, 2013 (edited) Copy the line below in blue word for word, and place it in the search box on eBay. You will find the correct shut-off valve with screen, plus a new grommet for only $8.99 and free shipping. Toro & Walker Gas Tank Fuel Shut Off Valve & Rubber Bushing •Fits 1/4" LINES To make your tank look like new, clean it good, then coat it with VHT Vinyl Dye. I use satin black. Makes the tanks look like new. Edited December 17, 2013 by rmaynard 1 Share this post Link to post Share on other sites
kudzu3 323 #4 Posted December 18, 2013 Thanks all... man them cables are expensive! Share this post Link to post Share on other sites
pacer 3,174 #5 Posted December 18, 2013 I just prowl ebay and find a throttle/choke setup that is plenty long - and cheap, and cut the existing control handle off and adapt my control then cut the remaining cable/housing to fit. I just replaced my D-160 with a 60" off ebay for $10, needed about 40" Share this post Link to post Share on other sites
Uncle Buck 246 #6 Posted December 18, 2013 Copy the line below in blue word for word, and place it in the search box on eBay. You will find the correct shut-off valve with screen, plus a new grommet for only $8.99 and free shipping. Toro & Walker Gas Tank Fuel Shut Off Valve & Rubber Bushing •Fits 1/4" LINES To make your tank look like new, clean it good, then coat it with VHT Vinyl Dye. I use satin black. Makes the tanks look like new. Not to hijack, but are you speaking of coating the inside of an old WH metal gas tank? If so I need to do that. Where do you get this stuff? Share this post Link to post Share on other sites
kudzu3 323 #7 Posted December 18, 2013 No sir uncle Buck (I actually had an Uncle Buck) , my tank is plastic and I just need to restore the outside. I used the stuff you're talking about in the tank of an old falcon I once had, it worked well. Just pour it in and shake it around and it coats the inside and seals all the little holes. I believe I got it at an auto parts store. 1 Share this post Link to post Share on other sites
