oldlineman
1979 c-101 8 speed transmission
oldlineman
I had the shiftier pull out of my tranny while pushing snow today. The screw that holds it in broke and the small piece in the tranny worked out far enough so that the shiftier pulled out of the tranny. I got the small piece of bolt out but am having a hard time getting the shiftier back in place. Is there a trick to getting this. Will have to get a new bolt at WH dealer.Any help from the experts will be appreciated. Need my horse back in service for the snow that is sure to come to western Pa.  Any info on adjusting the shifter screw would also be appreciated. Thanks
Edited by oldlineman
rmaynard
Both shift forks need to be lined up properly before inserting the shifter back into the hole. Check this post.
Edited by rmaynard
oldlineman
Thank you rmaynard those pictures where great, I think I will have to pull the fender pan so I can see into the tranny to line up the forkes. This is a great place to get excellent info and great support. I will get the bolt and get her back to what she likes pushing snow. Thanks again
rmaynard
Don't forget to get a new shifter boot if yours is bad. Little preventive maintenance goes a long way.
oldlineman
Thank you again, I replaced it several years ago it still looks good this tractor I had from new and has been nothing but a dream. Have a 89 414-8 also would own nothing but a Horse! Glad I ran into this form I do have some mechanic skills but the experience from other guys helps. Have a great and safe Holiday, MERRY CHRISTMAS !
rmaynard
Merry Christmas to you and yours as well.
JC 1965
Glad to see Bob was able to give you the help you needed. I see that you are fairly new here so  :WRS:
oldlineman
I got the set screw today at the WH dealer and the horse is back to work plowing snow. Thank you to all those that sent pics or advice, I will put a new boot on the shifter rod good advice to prevent future problems. Thanks again great forum!  oneoldlineman
  • Similar Content
    • davidfindlay
      By davidfindlay
      Looking to find a new home for my 84 (I think) C-145. It has a dump trailer with the enclosure for leaves, the PTO impeller to get the leafs into the trailer, the hoses for deck-to-impeller, impeller-to-trailer.
      I haven’t run it in over a year.
      The battery and the cable to the battery probably need to be replaced.
      Comes with a new head gasket still in the bag.
      Seat is cracked but still comfortable.
      Happy to answer questions or take other pictures.
    • giant_g2
      By giant_g2
      Not sure on specific model. This 8 spd came attached to a plow I bought. It had some water in it for a couple weeks according to the prior owner. I drained it, sloshed some diesel in it, drained that, then filled with fresh oil. Spinning the input shaft by hand, I can see the axels turn. Hasn't leaked any oil. I'm not really interested in shipping, so I'd prefer local sales.
    • 87 416-8 horse
      By 87 416-8 horse
      I’m looking for wheel horse tractors for sale or for parts in the Eastern Nebraska or western Iowa area. Preferably 8 speed manuals. Pm me or comment with what you have. The worst I could say is it’s out of my price or distance range. Edit: engine is not important, it’s going to get an engine swap.
      Thanks,
      John
    • BrianStasC-101
      By BrianStasC-101
    • HumbleHans
      By HumbleHans
      Operator manual 810343R1
      Wiring
      34 pages 17.5MB
      Wiring Colored
      1 page 228KB
