oaktown1987
sediment bowl
oaktown1987
does anyone know where i can get a good sediment bowl off ebay and its its junk i think its stens or rotary and does anyone know where i can get a good throttle cable for a 855 and back to sediment bowl should i keep it or eliminate i like keep it original but some things just need need changed
squonk
You can get a sediment bowl at Napa or TSC. I eliminated mine on my 704 and put on a good filter and shutoff. I hate fuel leaks.
flyovrcntry
Do away with the sediment bowl, they worked good for their time,but their time has passed. Filters work so much better,and no leaks.It's kinda like tubes for tires,that time has come and gone.
rmaynard
The only reason I use a sediment bowl is to keep my 701 all original. I found that the Briggs & Stratton bowl is a dead-on replacement for the original one from Wheel Horse. Having said that, I also put a mini filter inline between the bowl and the fuel pump.
Martin
i did the same thing as bob on my 1057. i like the look of the sediment bowl on the bottom of the tank, but was also concerned about filtering......
i think its a briggs sediment bowl, i picked it up from napa.
post-4321-0-63186500-1387121569_thumb.jp
Don1977
I got new bowl and screen from TLC when I dropped a broke the one on a 59 430 JD.
buckrancher
I prefer the sediment bowl over a fuel line straight from the tank thru a inline filter to the carb because.
#1 the micro mesh screen in the sediment bowl will filter out any particles large enough to clog up a
carburator
#2 water if you happen to get some h2o in your fuel a sediment bowl will keep it from getting in to the carb
where a inline filter will not and it also gives you a visual of whats going on in that repect
However I do like Martins setup if you feel you need the extra piece of mind
Brian
oaktown1987
The only new sediment bowls I find has the plastic nut that holds the glass bowl on
rmaynard
Do an eBay search for
Briggs & Stratton 690612 Fuel Filter, Glass Sediment Bowl
buckrancher
keep looking only buy the ones with the metal nut thier out there I normally buy two or three when I find them
Brian
oaktown1987
Found one well ordered 3 thank u guys
