jeremi3210
charger tow valve
jeremi3210
I have a rear end out of a charger piston to gear hydro dont know if its good. The tow valve on it turns and turns and turns?? Is that normal or is it striped?? If it is striped is there anyway to fix it??
TT
The tow valve can turn indefinitely, but only 1/2 turn is required to change from tow to drive.
Unless it's been tampered with, the long side of the roll pin should point forward to drive and to the rear to tow.
jeremi3210
Ok thanks tt. Now to figure out a way to bench test. Gonna try to build a narrow front with it.
Edited by jeremi3210
pfrederi
My opinion a bench test set may tell you if it works...however until you load it up and get it hot you will not really know how well it works.  I would put it on a tractor and then run/work it till it was hot them put it up against an immovable object with the rear wheels on pavement and see if it will spin the tires with you on it.
