Uncle Buck 246 #1 Posted December 4, 2013 (edited) I have an 857 horse that needs a fuel pump. The engine is the original 8hp Kohler. The tractor came to me that way so I do not have the original fuel pump either. I know that fuel pumps are no longer available as well. I was wondering if anyone knows if an electric fuel pump is a possible option? I suspect an electrical fuel pump would actually deliver too much fuel under pressure and flood out the carb. Am I correct in this assumption? Suggestions would be greatly appreciated. Edited December 4, 2013 by Uncle Buck Share this post Link to post Share on other sites
rmaynard 15,417 #2 Posted December 4, 2013 Try contacting buckrancher. He may have a good working mechanical one you can buy. 1 Share this post Link to post Share on other sites
Uncle Buck 246 #3 Posted December 4, 2013 Man I love this place, thanks a lot! Share this post Link to post Share on other sites
squonk 41,016 #4 Posted December 4, 2013 I use a electric pump on my C-160 with no problems 1 Share this post Link to post Share on other sites
Uncle Buck 246 #5 Posted December 4, 2013 I use a electric pump on my C-160 with no problems An automotive type? Share this post Link to post Share on other sites
bowtieguy 334 #6 Posted December 4, 2013 Herb...NAPA part number 610-1051....called a POSI-FLO fuel pump...1.5 to 4 PSI...I have a couple and they work well.... 1 Share this post Link to post Share on other sites
Uncle Buck 246 #7 Posted December 4, 2013 (edited) Herb...NAPA part number 610-1051....called a POSI-FLO fuel pump...1.5 to 4 PSI...I have a couple and they work well.... Thanks so much Frank. Really looking forward to getting that plow mounted to my rig. I want to get this fuel pump sorted out first though. So is that an electric fuel pump Frank? BTW: I really lucked out, BIL's repo buddy towed that truck back to Topeka for nothing! That helped a bunch and was a real help for sure. I owe that ol boy too! Edited December 4, 2013 by Uncle Buck Share this post Link to post Share on other sites
squonk 41,016 #8 Posted December 4, 2013 Here you go. 1 Share this post Link to post Share on other sites
MalMac 1,331 #9 Posted December 4, 2013 Unless you are dead set on a electric pump, there are aftermarket pumps for that motor. 1 Share this post Link to post Share on other sites
wallfish 16,980 #10 Posted December 4, 2013 Isn't the fuel tank above the carb in an 857? Going forward up a steep hill could be an issue without a pump. 1 Share this post Link to post Share on other sites
TT-(Moderator) 1,131 #11 Posted December 4, 2013 I don't have pics of any that I've converted, but I have used a modern B&S pulse pump on a few. You can buy or make a fuel pump block-off plate, drill a hole in it, and add a 1/4" barbed fitting to the center for the pulse line. OEM block-off plate: Purchase and install a B&S style pulse pump like this one: http://www.ebay.com/itm/390601028608 One additional 1/4" hose is all that's needed. No wires to worry about and it will even work on tractors that don't have a battery. The plastic pumps are so light that you can zip tie them to anything that will hold them or you can fab up a mounting bracket. 2 Share this post Link to post Share on other sites
Uncle Buck 246 #12 Posted December 4, 2013 Unless you are dead set on a electric pump, there are aftermarket pumps for that motor. Actually I am not dead set on one particular answer at all. If there is clearly one best option then that would be my likely choice. More than anything I am looking for reliability since this machine will be a worker. I will need good cold weather starting ability. Please offer your ideas as well, the more the merrier! Isn't the fuel tank above the carb in an 857? Going forward up a steep hill could be an issue without a pump. Yes, you are correct in what you say. I don't want to gravity feed this thing. Share this post Link to post Share on other sites
squonk 41,016 #13 Posted December 4, 2013 I've had fuel pump issues on 3 different Kohlers. 1 I rebuilt, another I replaced with a plastic body one and the third electric conversion. All work well. I like the electric because if I run out of fuel it will prime the line in seconds. I have one tractor with the rear tank and the original pump. When that pump fails I will install electric on that. 1 Share this post Link to post Share on other sites
