Dafixer 1 #1 Posted August 31, 2008 I purchased a used 36 inch tiller for my horse with no user manual and the toro on-line store cant seem to match one although the id tag is very legible. The model number is 0736tl04 manufacture date of 1990, I need to know how to check the case oil and adjust the lift properly when i mount it..after i gather the rest of the lift hardware..(any help here would be appreciated too)..thanks for any info Share this post Link to post Share on other sites
TT-(Moderator) 1,131 #2 Posted August 31, 2008 07-36TL04 works at the MPV. (you need the hyphen) P/N 810317 should be the manual and it is still available from Toro for less than $5. NOTE: If you use 79370 for a model number (1993 & up tiller) you can view a similar online manual at Toro.com. :banghead: Share this post Link to post Share on other sites
Dafixer 1 #3 Posted August 31, 2008 Got it ...thanks... :banghead: Share this post Link to post Share on other sites
