chazm
314-8 Brake pedal relocate
chazm
Hi guys, its been awhile since I've posted due to medical reasons. I have a question about relocating the brake linkage on my 314 to the clutch pedal like on my Raider10 . So 1 pedal works both clutch & brake. Has anybody done this or any ideas if it possible.  I have been looking at parts layout of both & looks like some changes in the linkage might work. Any ideas are welcome.
Thanks Chas
chazm
Thanks for the input
stevasaurus
Hey Chas...welcome back...I take it that you are OK. :)
Duff
Hi, Chas,
Sorry to hear about the medical issues, but glad you're on the mend!
Given the relative positioning of the linkages and the recommendation that you stop a grear driven tractor before shifting, I don't see why both couldn't be put on one pedal. I don't have any of my 310/312's torn down right now to look at, but going from memory it would seem to be a fairly simple conversion since the two linkages are very close to each other on the left side of the frame.
Others with ideas?
~Duff  :thumbs:
shallowwatersailor
You might look to Cub Cadet for ideas. The 582 Special that I have does use one pedal for both the brake and clutch. The brake is an external caliper but the clutch is inside the Peerless 2300 transaxle. It has twice as much travel to work both.
82df5b97-00de-42b8-aa48-43f53bba854a_zps
Martin
all the 60s wheel horses had clutch/brake on the one pedal. should be a matter of just finding the right parts to convert......
chazm
Yes Martin, I'm thinking the same thing... Looking @ my Raider 10 parts man. the clutch rod pivot arm look the same as the 314 ( diff. part numbers). I'm thinking that it should work if I
change the clutch & brk rods from the Raider  to the 314. But since I'm heading back to the hospital Dec 3 for hopefully my last surgery, I'll have to look into it  afterwards
Thanks for your thoughts & have a good Thanksgiving
Chasm
sorekiwi
I hate to agree with an Aussie, but Martin is right.  Just find all the linkages off an older model.  There may be some clearance issues with the foot boards if the linkages come from a pre foot board model.
baerpath
https://lookup3.toro.com/partdex/index.cfm?xCaller=Toro
Take # 26 out and all the rest thats with it, put #26 into #18  The extra hole is already there. On the brake band so it doesn't bind make a new hole on the outer side of the one there. You will have to thread #26 a lot farther and cut off the extra.
No extra parts needed we do this when we put gas peddles on the pullers
chazm
Good deal Duane,  :handgestures-thumbupright: . After loosing my right leg I need to make a change to the set up.
Thanks guys for all your help   :greetings-wavegreen:
Chasm ( aka "Stumpy"   :eusa-doh: )    :flags-waveusa:
stevasaurus
Chas, it looks like you are in good hands.  Do you still need the pictures?  Good luck with hopefully your last surgery.  :)
AMC RULES
God be with you Charles.
Good luck.    :handgestures-fingerscrossed:
  • Similar Content
    • BrianStasC-101
      By BrianStasC-101
    • FAST41
      By FAST41
      I am new to this group. I have my sons collection of Wheel Horse tractors that are definitely rare models. He still has one to pick up that’s dual wheel and was purchased from Peabody Coal Co. This is the perfect site to get involved with. The best advice comes from folks that are hands on.. had to be their own machine shop. Nothing compares to the knowledge in this group.! But my first topic is this 19hp Craftsman INDY 500 limited edition model. I was reading a topic on here about the 18hp and 20hp models, but cannot find a single replica of this tractor on ANY site or e-bay. We live near central Ohio, so I’m assuming it’s a regional release.The Briggs engine lobes like a medium cam in a V8. We thought it was an intermittent miss, but it’s not missing a bit. The engine is the strongest riding tractor I’ve ever operated. It will literally cook the deck belt in high grass before dragging the engine down. Very wide and lower to the ground. I never got the size, but the rearend is all tires.! Looks like a dragster from behind.. almost  gives the appearance of shortened axle tubes in a hot rod. Just wondering if anybodys ever seen this particular model. My next top is will be about the C160 total hydraulic Wheel Horse he just acquired. Claim they were specially made for snow removal.
    • Wendell
      By Wendell
      New to the forum, but not to Wheel Horse. I just bought a 314-8 on the gear shift pattern there is what Toro calls a spring shift control, my 312-8 doesn't have this The 314 is a 1999, what was the purpose for this. Thanks.
    • Bobbi Barroso
      By Bobbi Barroso
      Missing lift rod. Anyone know where to buy one or the dimensions to make one?
    • Tap53
      By Tap53
      List of various belt Lengths and Widths text
      Chart belt
      Belts sorted by part number pdf
      4 pages 458KB
      Belts sorted by belt section (cross section) pdf
      4 pages 422KB
