tmix 34 #1 Posted November 10, 2013 Would like to change fluid in trans could anybody tell how and what kind of fluid to use. It's a Raider 12 model 1 0310 6 serial 810845 Any help would be great thank you. T Mix 1 Share this post Link to post Share on other sites
Hodge71 664 #2 Posted November 10, 2013 (edited) Any good 80w-90 gear oil will work well. Raise the front of the tractor to about 40 degrees when draining so you can get the extra that lays in front of the hump in the transmission case. Refill with 2 quarts of gear lube and you're good to go. Might not be a bad time to check shift boot too. They're only about 6 bucks on ebay and will help make sure no moisture finds its way into your 8 speed. Good luck!! Edited November 13, 2013 by hodge71 Share this post Link to post Share on other sites
AMC RULES 37,134 #3 Posted November 10, 2013 That's an awesome calendar pict Tmix. Share this post Link to post Share on other sites
Kevbo 80 #4 Posted November 11, 2013 I have had great results with both Lucas and Mobil1 gear oil. Really makes shifting a lot smoother. I second the shifter boot! Check eBay! Share this post Link to post Share on other sites
tmix 34 #5 Posted November 12, 2013 Thanks much guy's Ya just got out of the fields was raking hay LOL Share this post Link to post Share on other sites
