travlinman
c-125 shifter loose
travlinman
just found a c-125 runs great , shifter is just kinda flops from side to side if I push and hold in gear will go in both hi and low range just fine but wont stay in gear unless I hold it in gear any ideas ??
rmaynard
Check to see if your dog-point set screw is loose.
AMC RULES
Where it goes into the trans...there a little set screw, down at the base of the shifter handle.
Probably just needs tightened up.   :handgestures-thumbsup:
        :WRS:
Edited by AMC RULES
