Bill Allert 68 #1 Posted November 10, 2013 Just mounting my nos snow plow I picked up, and noticed there are no skid plates although there are slots in the blade to mount a pair. I had printed out the manual for my blade, but they don't show any in the manual. Funny, I don't see any on some of your pictures either. I have used garden tractor blades in the past that do have them. Whats up???? Bill Share this post Link to post Share on other sites
KC9KAS 4,744 #2 Posted November 10, 2013 I am not positive, but most of the WH blades DON'T have the skid shoes on them. None of mine do, and I have 4--42" plows. The wider plows like a 54" or 60" for a GT-14 or D series has the skid shoes (I think). Share this post Link to post Share on other sites
jeremi3210 743 #3 Posted November 10, 2013 I just got done fabing some up for my 48" plow. If you want i can post some pics. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,845 #4 Posted November 10, 2013 Optional skids Garry Share this post Link to post Share on other sites
Bill Allert 68 #5 Posted November 10, 2013 Thanks, that's just what I was looking for! Seems like a simple project to duplicate! Might still be a good part number, have to check. Bill Share this post Link to post Share on other sites
sorekiwi 761 #6 Posted November 11, 2013 Some, (if not all?) of the big D blades had skids. Here is a pic: Share this post Link to post Share on other sites
pfrederi 19,264 #7 Posted November 11, 2013 Thanks, that's just what I was looking for! Seems like a simple project to duplicate! Might still be a good part number, have to check. Bill Part number is still good. i would imagine they will have them in stock for a long time. $32-36 EACH!!! They must be made out of some exotic endangered metal Share this post Link to post Share on other sites
wrightorchid 261 #8 Posted November 11, 2013 yes, good American steel seems to be getting more endangered by the day... Share this post Link to post Share on other sites
shorts 182 #9 Posted November 11, 2013 on a good smooth paved driveway running without the skids will let the blade scrape all of the snow resulting in clean pavement, the downside is that the scraper edge gets worn. If you have a gravel drive or uneven pavement the shoes help to keep the blade from getting hung up or digging into the gravel. Share this post Link to post Share on other sites
sorekiwi 761 #10 Posted November 12, 2013 Or you can use the dial-a-height adjuster on the lift lever to set the blade to just skim the surface. Share this post Link to post Share on other sites
js5020 111 #11 Posted November 12, 2013 Try a length of PVC on the edge, no skids necessary. Yes the PVC wears out but its cheap and easy to replace. Share this post Link to post Share on other sites
JC 1965 1,534 #12 Posted November 13, 2013 Try a length of PVC on the edge, no skids necessary. Yes the PVC wears out but its cheap and easy to replace. Do you run the PVC across the entire length of the blade ? Do you rip the PVG and use half ? I'm trying to picture this setup but having trouble. Share this post Link to post Share on other sites
js5020 111 #13 Posted November 13, 2013 I put a precut lenght on the tablesaw with the rip fence and adjust the blade height to cut through one side of the pvc, I am using 3/4 pvc and the kerf of the saw blade is enough and keeps it tight on the blade. ">http:// Its real easy to put on, once cut you get it started on one side and just "bump" it on. 1 Share this post Link to post Share on other sites
JC 1965 1,534 #14 Posted November 14, 2013 OK !! That makes perfect sense, Thank you very much and thanks for the pic. Share this post Link to post Share on other sites
timo4352 147 #15 Posted November 14, 2013 I like the PVC idea. I have skids on mine, but I'm still gonna try the PVC too. Share this post Link to post Share on other sites
boovuc 1,090 #16 Posted November 15, 2013 I use a very thick piece of heavy duty polyethylene, (HDPE), on the bottom of my snow blade. It doesn't tear up or scrap the blacktop yet it is hard and thick enough to break up ice. (Not as well as steel). Share this post Link to post Share on other sites
varosd 1,185 #17 Posted November 16, 2013 I use a very thick piece of heavy duty polyethylene, (HDPE), on the bottom of my snow blade. It doesn't tear up or scrap the blacktop yet it is hard and thick enough to break up ice. (Not as well as steel). I am using a piece of UHMW on my 48" blade and it's holding up great! 2 Share this post Link to post Share on other sites
pfrederi 19,264 #18 Posted November 17, 2013 I use a very thick piece of heavy duty polyethylene, (HDPE), on the bottom of my snow blade. It doesn't tear up or scrap the blacktop yet it is hard and thick enough to break up ice. (Not as well as steel). I am using a piece of UHMW on my 48" blade and it's holding up great! For us dummies what is UHMW??? Share this post Link to post Share on other sites
varosd 1,185 #19 Posted November 17, 2013 http://www.mcmaster.com/#standard-plastic-sheets/=pf51id Ultra high molecular weight polyethylene Share this post Link to post Share on other sites
js5020 111 #20 Posted November 26, 2013 Ive used this PVC setup on my Gravely walkbehind that is used on the lawn area for years without a problem of any kind, but today we got about 4" and I took the WH out to the stone drive for the first time,,,,,, the PVC did not hold up to the punishment, I dont think it lasted for half the drive, it shattered and started falling off,,, the WH did just fine though! Share this post Link to post Share on other sites
boovuc 1,090 #21 Posted November 27, 2013 Interstate Plastics online, half inch thick, 5 inches widse by 60" long HDPE strip would cost a little over thirty bucks. The HDPE holds up much better and is not brittle like PVC gets in could weather. I use three-quarter inch thick HDPE but that is special order sheets for work use. After we use it and it's no longer needed, I get it and cut them down to fit my blade. We use them as glides for a cleaning press. We change them out once every three to five years. My half inch strip I used a few years ago lasted two to three seasons. One of the seasons was on a stone driveway. (Got mine paved)! Share this post Link to post Share on other sites
