stevebo
November Tractor of the Month- Custom Workers !!
November Wheel Horse of the Month
66 members have voted
  1. 1. Pick tractor
    • Stevebo's 520HC
      4
    • Squonk's weight hood
      6
    • 953 Nut's Hot Rod 953
      5
    • Hodge71's 18 Auto
      5
    • Don1977's C120/180
      5
    • C-101plowerpower's C101
      3
    • Diesel Cowboy's C160
      6
    • Wheeledhorseman's Tiny Tim
      3
    • Sorekiwi's Ranger
      4
    • Stigians GT-14+2
      3
    • Smoreaus 417A
      6
    • Octfst's 867
      4
    • Walfish's cruiser
      12
kaiser
wallfish, that is cool as heck!
slammer302
This is my b80 that I drug out of a barn it was just rusting away so I gave it a new life I mounted a k241 on it and put a custom throttle lever on it from a old tractor out of all my nice WH this is what used to all summer
wallfish
Might as well show this one too since this one is a worker. Not as an entry but just to put it in a thread that's about customs.
Here's my homebuilt backhoe which has done plenty of work for a little machine. Spent 2 summers of spare time outside on the ground cutting, drilling and welding to get it together. By the end, I was sick of cutting, drilling and welding! Spent the winters researching the net for hydraulic info as this was my first time ever attempting to use them and building something this big from scratch.  Built using the plans from PF Engineering.com
Edited by wallfish
  • Like 4
953 nut
Thanks for all who have voted, not too late for the rest of you!
cjsdad
This is my little C-85.  I bought it mainly for the plow due to the snow we get here in the winter.  She started out a little rough.  Not nearly as much effort in restoring her as some of the works of art I see on here, but then I wanted a worker.
I replaced the fender pan with a metal one from a later unknown model that I bought off ebay.  The plastic fenders were so rotten they would crumble at the slightest touch.  I used the original plastic mounting base as a spacer for the metal one and only needed to cut out for the fuel tank.  Worked perfect.
I wouldn't really call the Craftsman plow a modification, but more of an adaptation.  It works great though.
When it's all together the Little Horse looks pretty serious.
953 nut
:text-coolphotos:    Love the executive office chair seat! :woohoo:
cjsdad
36_15_271_zps52c3ab1c.gif  Yeah, that chair has almost run it's course.  It is starting to disintigrate.  I already took the arm rests off, couldn't get my fat butt in the chair with 'em on!  I have another seat that resembles the two-piece WH seats to go on.  I just need to cover it with vinyl first so I can just wipe it off and go when it is covered with snow.
davey40181
the work that went into this was puttin on the dual wheels and the exhaust and some electrical work
stevebo
And the winner is .................. Wallfish's Custom Cruiser !!! Congrats John !! Now you need to build another one !!
wallfish
Thanks to everyone who voted!
This could be one that I do again since there may be enough spare parts around. It did get lots of attention at the shows and apparently people like the style of it. It's just getting tougher and tougher to come up with new ideas for something that hasn't already been done.
  • Similar Content
    • BuffaloD200
      By BuffaloD200
      Finally getting around to working on my ark loader.  The previous owner said he thinks the problem is with the spool valve.
      As I've learned a bit more about hydraulics now, I'd like to get this all sorted out.
      I noticed the power beyond port is connected to the reservoir return.  Is that right?
      Anyone see anything blatantly incorrect?
    • ccs002
      By ccs002
      Looking for a complete hydro pump for a D-160. Tractor is missing everything from the rubber coupler disc back. Also willing to buy a complete tractor for parts, the closer to Harrisonburg VA the better. Thank you.
    • tractorboy79
      By tractorboy79
    • BuffaloD200
      By BuffaloD200
      '74 D-180
      My friction disc in gone on my clutch.  I saw the old post about making a new friction disc, so I'm not concerned about that.
      I managed to remove the front clutch plate and double v-belt pulley.  But I can't separate the two.  When I took the assembly off the spiraloc washer popped off on its own.  I HAVE READ THE MANUALS.
      So I should be able to just remove the pulley from the front clutch and continue with step 4.  The v-belt pulley is loose as all hell and flops around like a dead fish.  It seems to be hung up on a ring or bearing race.
      So my thoughts are grab a BFH or sparky the blue tip wrench.
      Is there an unpublished step 3.5, or some trick?
    • BuffaloD200
      By BuffaloD200
      Hey all,
      My '74 D180 has a lot of trouble pushing snow.  Weighted tires, but nothing else at this time.  I've found it gets stuck frequently and only one wheel spins.  Do these tractors not have a limited slip/locker arrangement?  How does everyone manage with the infamous one wheel peel?
