Horse Play 393 #1 Posted November 2, 2013 First of all - is it a stupid idea spending money to add e-start to a Tecumseh? It's actually a great motor - doesn't burn a drop of oil and and has a lot of power. Would this be an easy task? Share this post Link to post Share on other sites
Terry M-(Moderator) 2,215 #2 Posted November 3, 2013 (edited) Can you post a picture of the engine?? Then we could see what you have. Does the flywheel have a ring gear already ? does the shroud over the flywheel have an opening for a starter. I'm sure theres already threaded holes to mount the starter. I'm guessing the engine has no charging system…but you wouldn't need one anyway. Not a stupid Idea, all depends on you and what you want to spend…. Edited November 3, 2013 by Terry M Share this post Link to post Share on other sites
Mr. 856 170 #3 Posted November 3, 2013 should be able to as long as you have the gear and shroud to allow you to do so. they make a kit you can purchase to do it. that comes with the starter, etc. however I believe you could convert your engine to allow for it if you don't have the ring gear on the engine. Share this post Link to post Share on other sites
Horse Play 393 #4 Posted November 4, 2013 I think I should be good with the flywheel gear and there is a removable piece to put the starter, but what about a mag. for charging? Here's some pics: Share this post Link to post Share on other sites
pfrederi 18,586 #5 Posted November 4, 2013 I wouldn't bother with the magneto and regulator issues. I put an electric starter (but no charging system) in my Lawn Ranger several years ago. She has an HH70 Tecumseh. She is used 3-4 times per week all year long. She pulls a trailer and is a chore tractor so there is a lot of starting and stopping. The battery lasts for a month or more before i have to put a charger on it.. even in the winter. Like all good Tecumsh's she start quick (faster than the Kohlers I think in the 7-8 years I have had the set up I have had to use the rope 2-3 times because I hadn't charged her recently. Share this post Link to post Share on other sites
