C-101plowerpower 1,606 #76 Posted November 25, 2013 i like it:) looks a bit too high in the front though Koen Share this post Link to post Share on other sites
posifour11 723 #77 Posted November 25, 2013 How does it steer? Share this post Link to post Share on other sites
meadowfield 2,616 #78 Posted November 25, 2013 How does it steer? Surprisingly well, I thought it might be heavy but it's actually quite light. Share this post Link to post Share on other sites
Stigian 1,234 #79 Posted November 25, 2013 She's looking good Mark, that should be plenty of articulation on the front Share this post Link to post Share on other sites
Lars 526 #80 Posted November 25, 2013 Wow.. that's going to be a really cool horse Mark.. and like Ian said plenty of articulation on it..awesome. Share this post Link to post Share on other sites
timo4352 147 #81 Posted November 25, 2013 Really cool. This pic belongs in the calendar thread . 3 Share this post Link to post Share on other sites
Sparky-(Admin) 21,547 #82 Posted November 25, 2013 Looks great! So with the 4x4 engaged is there any binding when making turns? Mike........ Share this post Link to post Share on other sites
meadowfield 2,616 #83 Posted November 25, 2013 (edited) Looks great! So with the 4x4 engaged is there any binding when making turns? Mike........ That's the last bit, I had to make everything else fit before committing to the final drive. There's an intermediate shaft to go ahead of the tranny that increases the drive ratio. The drive will be taken from the brake drum as it is a fixed 12:1 ratio and pretty handy. The front axle can be disengaged and that linkage is already complete as 4WD only needs to be used when the rear wheels lose traction. Even though I have measured and designed Ackerman steering, when the front axle is driven it will cause wind up, causing the front wheels to scrub and affect the turn radius. Edited November 25, 2013 by meadowfield Share this post Link to post Share on other sites
Don1977 604 #84 Posted November 25, 2013 i like it:) looks a bit too high in the front though Koen It sits just right in the front, need larger tires in the back with the rear fenders raised and the footrest modified to make room. Share this post Link to post Share on other sites
meadowfield 2,616 #85 Posted November 26, 2013 i like it:) looks a bit too high in the front though Koen It sits just right in the front, need larger tires in the back with the rear fenders raised and the footrest modified to make room. I did that with my sons, I think I might lower the tranny by 2 inches and see how it goes... Share this post Link to post Share on other sites
js5020 111 #86 Posted November 26, 2013 Nice "upgrade"! Id really like to see details on the drive and how your going to transmit power to the front. Share this post Link to post Share on other sites
AMC RULES 37,141 #87 Posted November 26, 2013 Really cool. This pic belongs in the calendar thread . No, this one. 2 Share this post Link to post Share on other sites
js5020 111 #88 Posted November 26, 2013 How about Both??? Excellent pics and it definetly has "the look" in both. 1 Share this post Link to post Share on other sites
meadowfield 2,616 #89 Posted November 26, 2013 How about Both??? Excellent pics and it definetly has "the look" in both. thanks guys! I think I might just print both and put on my wall 1 Share this post Link to post Share on other sites
meadowfield 2,616 #90 Posted November 26, 2013 Nice "upgrade"! Id really like to see details on the drive and how your going to transmit power to the front. thanks, there is a definite plan. Maybe I'll post some more pics this weekend... Share this post Link to post Share on other sites
meadowfield 2,616 #91 Posted November 26, 2013 (edited) As I'm home for a few days, managed a few hours earlier Turning down the inside of the brake drum to 30mm Then turning down a sprocket to fit over the shaft. The two together, the drum now fits on reversed with sprocket on the outside. To complete the story, here's a snapshot of the intermediate gearbox calculator. I just input the two axle gear ratios, tyre diameters and preferred pulley sizes. The calculator tells me what sprocket sizes I need to get the closest match. Edited November 26, 2013 by meadowfield Share this post Link to post Share on other sites
meadowfield 2,616 #92 Posted November 28, 2013 (edited) Disastrous update... Firstly turned a ring to fit inside the drum in order to lock the sprocket and align it. Then turned the inside of the drum to make it a tight fit. Then welded the two together, they just about weld... The brake drum is very powdery and very interesting to turn Then pushed the two together and pushed the drum back onto the transmission to see the fit. Ouch!!! As I pushed it onto the shaft I trapped my thumb on the brake band and my nail has gone black!? not done that for a while... Then the real disaster The sprocket should be an 08B and clearly it isn't! The chain rides high and the tooth width is too small. I wish I had noticed before I did the work boring the centre. That's going to be it for now as I'm away for a few days. Edited November 28, 2013 by meadowfield Share this post Link to post Share on other sites
js5020 111 #93 Posted November 28, 2013 Nice machine work,, to bad on the sprocket though. Share this post Link to post Share on other sites
AMC RULES 37,141 #94 Posted November 28, 2013 I feel you pain... smashed my thumb early August, trying to remove a stuck hitch pin. Only recently started to feel, and look normal again. Share this post Link to post Share on other sites
953 nut 56,165 #95 Posted November 29, 2013 (edited) I don't think I would change the tire size, just make up an adapter plate to elevate the rear two or three inches at the tranny mount. You already have the gearing worked out with the tires that are on it, going to bigger tires would change that. Edited November 29, 2013 by 953 nut Share this post Link to post Share on other sites
meadowfield 2,616 #96 Posted November 29, 2013 I don't think I would change the tire size, just make up an adapter plate to elevate the rear two or three inches at the tranny mount. You already have the gearing worked out with the tires that are on it, going to bigger tires would change that. Tyre size is fixed, I like the look and as you say the gearing is sorted. I will probably do the same to the rear as I doc with my sons. Weld a two inch piece on the bottom of the tranny mount and move the tranny down a few inches. It's easier than moving the fender, etc. Share this post Link to post Share on other sites
meadowfield 2,616 #97 Posted December 4, 2013 The last update was really annoying, fortunately the company that shipped accepted their mistake and sent the correct part this time. That mean that the last mods to the brake drum had to be undone... Careful use of the grinder and a hammer! Note the casting broke instead of the weld. The inside was cleaned up and the sprocket fits inside using 3 screws to hold it in place. Finally getting me to where I should have been a week ago. 1 Share this post Link to post Share on other sites
posifour11 723 #98 Posted December 4, 2013 Looking great. Your skills are amazing. Keep it up! Share this post Link to post Share on other sites
meadowfield 2,616 #99 Posted December 5, 2013 Bit cold and windy up north today... Painted the front wheels indoors, swmbo (the boss) not happy with the smell of paint and thinners. Drive belt and bearings arrived today Mock up to check the fit and general idea - final implementation will not be made from wood Share this post Link to post Share on other sites
Anglo Traction 761 #100 Posted December 5, 2013 Bit cold and windy up north today... Painted the front wheels indoors, swmbo (the boss) not happy with the smell of paint and thinners. Ahh Bless 'em , the Ladies don't like the smell of paint in the house, but Nail Polish and the Remover fumes are ok . Glad your back on track, looking good and the Black Thumb Nail is on the mend . Share this post Link to post Share on other sites
