jhunsch 20 #1 Posted October 24, 2013 19 Foot Long Pole Saw. Made it myself long pole saw for about $20. First you need to get lucky and find the right Saw blade. I happened to get real lucky and asked the right young lady @ Lowes for help. I got the last out of package reduced pull type limb saw that Lowes had for $ 3.90. Plus small bolts and wing nuts for $ 4. And the In expensive conduit for just a couple more bucks. One 10 footer ¾ inch & One 10 footer 1 inch in diameter. Total length is 19 feet it is a bit cumbersome to use, and just a bit heavy. Operator need to be patient and work slow. Its important the blade is a pull type blade. This means the blade only cuts the material when it is pulled towards you. Cutting on the push does not work well at 19 feet. Also use a wax type lubricant on the blade. This helps a great deal to make the job easier. Mount the blade @ that typical slight angle. I used a piece of broken sledge hammer handle inside the pipe to mount the blade. I turned it down on a lathe to fit, then cut the slot with a saws all. Two bolts with jam nuts to hold the blade tight. Ten cuts later, its all still tight so I think it turn out all right and cut’s fast to. Two bolts with wing nuts hold the two pipes together. I over lapped them about 1 foot. I can reach up over 20 feet and cut. When I store it I have the pole slid together. One Bolt and wing nut hold to two together the other bolt is just in the handle end so I know were it is. If or when I need it only half way extended I will drill those holes then. 3 Share this post Link to post Share on other sites
953 nut 57,861 #2 Posted October 25, 2013 You could bring it over to my house and show me how it works. Share this post Link to post Share on other sites
AMC RULES 37,145 #3 Posted October 25, 2013 Great idea...I need one too. Share this post Link to post Share on other sites
GlenPettit 1,717 #4 Posted October 27, 2013 A "Chain link fence TOP RAIL" is 21' long, one piece; but probably heavier. That is a great idea. Share this post Link to post Share on other sites
Rboski 114 #5 Posted November 11, 2013 (edited) That sure beats having to be the "Pole" in the tree with a saw. Jeeeez, nobody likes polish jokes? Edited November 17, 2013 by Rboski Share this post Link to post Share on other sites
eb in oregon 28 #6 Posted December 2, 2013 Pole saws are a good tool to have, but the longer ones will wear you out. I built a rather long saw myself some years back and used the heck out of it. But gosh darn, after cutting a good sized limb or two, your done for the day. I used an eight foot length fiberglass pole (retrieved from the garbage bin at a place I used to work) and a eight foot length of wooden rod meant for a closet rod. It just fit into the fiberglass tube and was secured with two wood screws. It was just shy of sixteen feet. I cut the slot for the blade (rescued from a pruning saw with a broken handle) with a cross cut saw and used two 1/8th inch carraige bolts to secure the blade. It's still in the garage, but I loath having to take it out. Share this post Link to post Share on other sites
