Charlie Smith
Head Gasket Help.
Charlie Smith
Hello All
Recently my poor little raider10 has been suffering abit, I've got a blown head gasket, it's been going strong but it's getting worse, with this colder weather coming I've brought a new head gasket for it, it's being shipped and is on it way, however this is the question where I need you guys,
I have a Raider 10 with the Tecumseh HH100 10HP engine, once I replace the head gasket, is there a torque that the head bolts need tightening too? Or?
Many thanks
WH nut
What size bolts, if they are 3/8s they are torqued o about 27 ft pound 5/16 about 18
Martin
the manual says to torque them to 220-224 inch pounds. which should be around 18 ft lbs.......
heres a manual link...
rick
In addition, you need to torque the bolts in the proper order, and in 50 inch pound steps.
Kelly
Also when you have the head off make sure it is flat, there are a few ways to do so, sand paper on a known flat surface and sand the head using a circular motion, till it looks flat, I have a 3" wide file I run over the heads in a cross pattern, or set it on a belt sander for a few passes, take it to a machine shop and have them true it up, how ever you do it, if it is flat it will seal better, and hold the gasket longer.
Hodge71
Good Info Kelly. I found that out on the one Suburban I bought. It had a bad gasket on the Kohler and when I checked, the head was way out. My Dad and I sanded for quite awhile til it was true. New gasket hasn't had an issue since then.
