mcknigb 0 #1 Posted October 19, 2013 I have a 1994 314 wheelhorse with a 48" side discharge deck with a bad spindle in the middle. I have removed the nut and lock washer, but cannot get the pulley to break free to replace the spindle. any help would be great on how to replace this spindle. I have a old deck with good spindles on it. The mower model number is a 75360. Share this post Link to post Share on other sites
daveoman1966 3,738 #2 Posted October 19, 2013 (edited) This has worked well for me.... don't be bashful. 1) take the blade off and remove the grease fitting 2) locate a coffee can and put it under the deck, on a cement floor, with the spindle hanging in it. 2a)...the coffee can MUST be level on the floor and flush with the deck. Set another coffee can at the other end if necessary. 3) Locate a round tube (or another pulley) with 3/4" center, a couple inches long....plumbing pipe short nipple or short connector is ok. 4) Locate a short 5/8" bar that fits inside the 3/4" tube. 5) locate a nut just big enough to fit inside the tube (it will protect the grease fitting threads) 6) Set the nut onto the spindle shaft, then the 3/4" tube, then 5/8" bar into that tube. The bar should protrude no more than 1/2" or so. 7) HAMMER TIME..... Hold flat end of ball-peen hammer on the bar and WHACK it with some VIOLENCE with a much BIGGER HAMMER. 8) This will drive the spindle shaft down thru pulley and spindle...in the can. I should come off with the first WHACK. If not, you didn't hit it hard enough...go pcikup the parts and try again. 9) NOTE....you don't want to bend the shaft here. That's why a I say to hit it HARD. The more time you have to hit it, the more likely it is to bend. Edited October 19, 2013 by daveoman1966 2 Share this post Link to post Share on other sites
mcknigb 0 #3 Posted October 19, 2013 Thanks, I really appreciate it, I did what you said and it popped out the 2nd hit.. Share this post Link to post Share on other sites
Don1977 604 #4 Posted October 20, 2013 Take the snap ring out that is below the bottom bearing before you use a hammer on the spindle if not you could destroy a spindle housing. Share this post Link to post Share on other sites
