kudzu3
Is it okay to---
kudzu3
Is it okay to paint the cooling fins on the head and engine (181)? Although the tractor will not be used for work, I'm concerned about over heating, will paint effect this?
953 nut
Pain away, they had pait on them from the factory. A good quality engine pait should hold up well.
:USA:
kudzu3
Kinda what I thought, I'll be using rustoleum engine paint. Thanks
Kelly
I paint all of mine keep the alum from oxidizing
Coadster32
Just make sure the tins are on the block and you should be fine. :handgestures-thumbupright:
zanepetty
I asked the same question, tommy.
