WHPuller 1 #1 Posted October 11, 2013 I have a 10 pinion rear end that is blown (wipped out the pinions) I was wondering if you could swap the 8 pinion carrier and axles into a 10 pinion housing? The 10 pinion is 1 1/8" axle and I found an 8 pinion carrier, no axles on ebay for a reasonable price. Will the axles from the 10 pinion work with that carrier? The ad says they were 1 1/8" axles but were sold separate. Share this post Link to post Share on other sites
jeremi3210 735 #2 Posted October 12, 2013 The 8 pinion axles are both the same size the 10 pinion axles are different one is longer than the other. You can put a 8 pinion in where a 10 pinion was but you have to clearance the bull gear some. Theres a post on here that tells you what to do. Share this post Link to post Share on other sites
stevasaurus 22,872 #3 Posted October 12, 2013 I believe there is a "Service Bulletin" that deals with exactly what you want to do. It should be in the Manuals Section under "Service Bulletins". Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,102 #4 Posted October 12, 2013 Service bulletin Garry Share this post Link to post Share on other sites
