gabby
where can I find what snowblower fits my 520
gabby
will a 6900759 blower fit my 529h 6900759?
I meant to say 520h
my 520h is 6900148
Dieselcowboy
I'll piggy back on this and ask will a regular old single stage used on a C series or equivalent work?
gabby
no piggy backing I need my question answered,.
zieg72
Yes
I meant to say 520h
my 520h is 6900148
That # looks to be a serial #, we need a model # to answer your question
gabby
model # of tractor is 73502   thanks
cheesegrader
79361 is the two-stage
single stages with the attach-o-matic should fit too.
gabby
I guess i'll call the dealership tomorrow and ask them,then I'll post the answer.  thanks.
thanks cheeseburger,how can I look it up?
gwest_ca
You can get to the attachment list here
https://lookup3.toro.com/partdex/index.cfm?xCaller=Toro
Enter the 73502 and then select the 1996 link to the attachment list on the right.
The single-stage snowthrower is model 79360
The two-stage snowthrower is model 79361
Can not identify a model by it's serial number. Serials 1991 and up determine the model year.
Since these changed very little over the years models back to 1973 for the C-Series except C-195 will fit.
Make sure you get the lift tube and flag with it.
There are similar models that fit the vertical shaft engine models but won't work on the horizontal shaft engine models like you have in the 520.
See if you can get a model number.
Garry
gabby
thank you that was very helpful
gwest_ca
Is it a one-stage or two-stage?
Garry
Kelly
Where are you located ?? I have a few blowers that will fit a 520
New wheel
520h. First winter since I fixed this tractor up. Where can I find instruction to mount the blower. This is old school 1988. Also when removing my 48 deck I found the lift bar #112445 broke. The pin that runs side to side to the frame broke off at bar closer inspection it had been welded before . Is this needed for snowblower mount? Now I know why I wasn't getting much lift on the deck.
ericj
the bar you talk about is not needed for the snow blower after i started to respond i saw you are very close i have extra lift bars if you want to go that way i'll pm you my contact info
eric j
ps i'm installing a single stage snow blower on my 416-H today so if you need some assistance let me know i can give you some pointers
Edited by ericj
  • Similar Content
    • Donavon1
      By Donavon1
      Project black Betty the diesel 1054
    • BrianStasC-101
      By BrianStasC-101
    • FAST41
      By FAST41
      I am new to this group. I have my sons collection of Wheel Horse tractors that are definitely rare models. He still has one to pick up that’s dual wheel and was purchased from Peabody Coal Co. This is the perfect site to get involved with. The best advice comes from folks that are hands on.. had to be their own machine shop. Nothing compares to the knowledge in this group.! But my first topic is this 19hp Craftsman INDY 500 limited edition model. I was reading a topic on here about the 18hp and 20hp models, but cannot find a single replica of this tractor on ANY site or e-bay. We live near central Ohio, so I’m assuming it’s a regional release.The Briggs engine lobes like a medium cam in a V8. We thought it was an intermittent miss, but it’s not missing a bit. The engine is the strongest riding tractor I’ve ever operated. It will literally cook the deck belt in high grass before dragging the engine down. Very wide and lower to the ground. I never got the size, but the rearend is all tires.! Looks like a dragster from behind.. almost  gives the appearance of shortened axle tubes in a hot rod. Just wondering if anybodys ever seen this particular model. My next top is will be about the C160 total hydraulic Wheel Horse he just acquired. Claim they were specially made for snow removal.
    • Wendell
      By Wendell
      New to the forum, but not to Wheel Horse. I just bought a 314-8 on the gear shift pattern there is what Toro calls a spring shift control, my 312-8 doesn't have this The 314 is a 1999, what was the purpose for this. Thanks.
    • Bobbi Barroso
      By Bobbi Barroso
      Missing lift rod. Anyone know where to buy one or the dimensions to make one?
