BairleaFarm 340 #1 Posted August 26, 2008 How long should a battery sit before it loses its charge? Ive got a 10hp kohler s/g that has been sitting for a few weeks. You have to crank and crank to get it started and It didnt have enough to do it. I would think one of these tractors should be able to sit several weeks before the battery goes down. The battery is only a month or so old. Share this post Link to post Share on other sites
rocking 416 1 #2 Posted August 27, 2008 where did you get the battry? and what are the cranking amps? Share this post Link to post Share on other sites
rustbucket 4 #3 Posted August 27, 2008 personaly i use tractor supply and go for the max amps and cold cranking i can get. 360 is what most my horses have in em if not dead batteries from purchase of machine to be replaced Share this post Link to post Share on other sites
rocking 416 1 #4 Posted August 27, 2008 i agree tractor supply are good battrys.. walmart has decent ones for 25$ there 360 cranking amps they usally last 3-6 months depends on how hard you are on them.. the one in my 416 has been great . but her alternator is perfect so i guess that helps alot :banghead: Share this post Link to post Share on other sites
BairleaFarm 340 #5 Posted August 27, 2008 I got the battery either at TSC or AutoZone. I dont recall and cant read the amps because i painted it. red battery = unreadable. Here is a picture of it unpainted but of coarse i cant see the lable. Share this post Link to post Share on other sites
linen beige 14 #6 Posted August 27, 2008 walmart has decent ones for 25$ there 360 cranking amps they usally last 3-6 months depends on how hard you are on them.. I think you must have something draining your batteries, or not charging them fully. I have a now 3 year old Wal-Mart 360 cca battery on my 702, and a 2 year old Home Depot 360 cca battery on my 1054a. The 'Horses will fire right up after sitting for weeks. Neither of these two get run for more than a few minutes at a time, seldom over half throttle, and they recharge the batteries just fine. I also have a Wal-Mart 360 cca battery on my Crafstman that will start it's Kohler right up every spring after sitting over the winter in an unheated shed. That battery is 4 years old, and replaced one that lasted 7 years. I only use it for about an hour a week. Share this post Link to post Share on other sites
