zanepetty
leaking carb
zanepetty
Hey again everyone. I've gotten SO much done on my tractor thanks to this site and most of all my new friend stevasaurus. What a great guy. Anyway my carb bowl is leaking around the bolt. I tried a small rubber washer but it stretched around the bolt. Should I try a bigger one?
MalMac
More than likely the bowl has small hairline cracks in it around the bolt, the cracks are not really visible until you put pressure on it from tightening the bolts. You will need to just replace the bowl.
zanepetty
Oh OK I gotcha. So can I buy a bowl new or will I have to look on eBay?
zanepetty
I found one. Thanks for the help!
buckrancher
besure to use a new red fiber washer under the bolt
brian
zanepetty
OK I'll pick one of those up too. Thanks , Brian.
Edited by zanepetty
zanepetty
Where can I get one of those washers?
buckrancher
they are part of the rebuild kit your local toro dealer may have them
zanepetty
OK. I called my Kohler dealer and they said that the kits were obsolete?
953 nut
Sellers on ebay have lots of carb kits to offer at rather fair prices, just check the feedback before you buy.
:USA:
tunahead72
Try somewhere else...
NAPA
OPEEngines.com
PartsTree.com
JacksSmallEngines.com
Check RedSquare Links (under Wheel Horse Reference) for some other ideas.
Edited by tunahead72
  • Similar Content
    • Donavon1
      By Donavon1
      Project black Betty the diesel 1054
    • bigbuck
      By bigbuck
      I had a fire in 2019 which destroyed my pole barns and some wheel horse tractors and parts. i'm looking for someone who can use the engine that went thru the fire. It is not pristine but there must be some usable parts
      please call George at 517-499-5678 for more info.
    • cJ_3D
      By cJ_3D
      Hey all!
      Replacing the drive belt on my 252-h. Anyone know the torque specification for the center screw when I put this pto clutch back on? I know it was on there tight it took a minute for the impact to break it loose. Thanks!
      CJ
    • bkarp@roadrunner.com
      By bkarp@roadrunner.com
      my magnum 12 kohler all of a sudden is blowing oil out of the carb. if rings are bad should oil be blowing out of the muffler.thanks for any help brent
    • Tinman1962
      By Tinman1962
      Recently got hold of a 656 it's has a "newer" 61/2 Briggs on it I don't believe that's right any ideas about that
