djmil11 0 #1 Posted August 26, 2008 the deck has been welded, had to order a couple parts for the easy twin, and now she is sitting on my c-125. :banana: yes those are 8" rims, and as long as i make wide left turns there wont be a prob. until i find some 6" rims. i also ordered the high lift blades for the deck. i think they saw me coming. Share this post Link to post Share on other sites
DMESS 24 #2 Posted August 26, 2008 Another alternative would be 520-HC/1990 and up 520-H axle/spindles/wheels if you really wanted to keep 8's on the front. 'Course that creates a clearance problem if you have a dozer blade without the extension kit. 6" wheels might make more sense, but you will still want the taller spindles that are used with those. Try to find someone parting out a 308, 310, 312 or early 314 and get the whole setup. You'll like the bagger. It works very well and the 37" offers a beautiful cut. :banghead: Share this post Link to post Share on other sites
Rollerman 290 #3 Posted August 26, 2008 Dan where are you located in MI? I have more than a few 6" front tires/wheels & the correct spindles. You'll like the bagger with the leaves. I have a PeCo power vac & it worked great for them last year. Share this post Link to post Share on other sites
djmil11 0 #4 Posted August 28, 2008 i am just outside mount clemens ,MI 48047 is the zip :banghead: Share this post Link to post Share on other sites
