buckrancher 2,694 #26 Posted December 29, 2013 (edited) I think your setting on the flat ledge in the cup I checked height between the two parts I think your bottoming out on the top cover on the flat in the lower cup where the fliter screen is Brian Edited December 29, 2013 by buckrancher Share this post Link to post Share on other sites
AMC RULES 37,141 #27 Posted December 29, 2013 Either way...this modification worked... the oil bath is full, and the engine is running fine. 1 Share this post Link to post Share on other sites
buckrancher 2,694 #28 Posted December 29, 2013 if you ever make another one just don't drill the hole as big in the top cover so the pipe does not come thru it Brian 1 Share this post Link to post Share on other sites
AMC RULES 37,141 #29 Posted December 29, 2013 Agreed, that's the ticket here. I had to take the chance though, and figure it out as I went...as I had no reference on hand to work from. Suppose I could tack in a couple fender washers to the underside of the lid to prevent this tube from coming up through the cap. Next one will be even better...now that I know. Thanks again for your help Brian. 2 Share this post Link to post Share on other sites
buckrancher 2,694 #30 Posted December 29, 2013 I'm going to do the red one I took pictures of going to put a 1 1/8" dia. hole in top cover and spot weld a 1 3/16" freeze plug in the bottom cup I will post some pictures when I get it done Brian 2 Share this post Link to post Share on other sites
AMC RULES 37,141 #31 Posted December 29, 2013 Awesome, I'm sitting on a pile of 'em over here. Share this post Link to post Share on other sites
buckrancher 2,694 #32 Posted January 6, 2014 Heres my downdraft to updraft air cleaner conversion top has 1 1/8" dia hole Bottom has a 1 3/16" freeze plug (Dorman #555-086) with 9/32" dia hole on center freeze plug is a light press fit in air tube Brian 3 Share this post Link to post Share on other sites
Aldon 4,827 #33 Posted May 10, 2017 Just curious what years/models were the oil bath filters installed on? Was it limited to engine type? Kohler vs Clinton? 1 Share this post Link to post Share on other sites
953 nut 56,164 #34 Posted May 10, 2017 I won't walk through that mine field. You are bound to get a lot of answers followed by a lot of contradictions; should be interesting! 1 Share this post Link to post Share on other sites
buckrancher 2,694 #35 Posted May 10, 2017 55 Clinton 1200's and 55/56/57/58/59 kohler k90/91's also the larger kohler motors in in some of the early tractors 953 and some others Brian 2 Share this post Link to post Share on other sites
