wh1257
international TD 6 magneto help
wh1257
Hi I have problems with the ignition of my TD 6 first I normally start on gasoline before I could run on diesel, but I have an ignition problem does not work, I have it all inside but made clear he does not fire I have the power of the distributor and it stops anyone can help me, I'm desperate
mvg vincent
C-101plowerpower
time for new spark plugs?
FarmerJim
Hi Vincent. The top of your post says magneto. Can you tell me what kind of magneto it is ? all the old equipment I have ever worked on if it had a magneto the first thing I always did was change the condensor. It is the least expensive piece in the magneto and usually the first thing to fail, and if it fails you will have very little spark or no spark at all. best regards, Jimmy
