buckrancher
Kohler K160 #230075 coil replacement
buckrancher
I recently bought a Kohler k160 motor that I was told had a broken rod which was ok as all
I wanted was the ignition system off it for another motor
upon closer inspection I found that the motor was siezed and that the rope starter pulley was loose on the crankshaft and shucking back and forth
I deceided to remove the tinware and cylinder head and give the piston a good soaking with penetrating oil a couple of hours later some light raps with a hammer handle and the piston was moving up & down and no broken rod
next I cleaned the points and hooked the spark plug back up to check for spark
Nothing at all so off with the flywheel and find this is the problem
Got out the good old Kohler engine parts book and find that I need a #230075 coil which is NLA
soooo on to E-Bay found a used one for $200.00 :banghead:
The next few hours I spent  searching online and this is what I found
The ignition system is a Bendix Scintilla magneto ignition system this system was used on small
one and two cylinder motors
and that some old mercury outboard motors used them also
I found several web sites that sold vintage outborad motor parts and which had new reproduction
bendex scintilla coils for around $60.00 bucks so I ordered one
mounted on the motor the only thing i needed to do was lenghen the condenser wire
the coil seems to be a exact replacement for the kohler part number
after this I lapped the head and replaced the head gasket also new condenser ,points and spark plug
also a complete carb rebuild without using any NC chem dip and a differant gas tank and line
new muffler too
1766bcbd-9a7a-47f6-9d8d-b3d1e3dc7a13_zps
sorry for the back ground noise in this video as my cnc machine was running behind the camera
runs pretty good for sixty plus years old :icecream:
Brian
Edited by buckrancher
  • Like 5
rmaynard
Bravo. :greetings-clapyellow:  If anyone can get a 60 year old engine running, it's gotta be you. Good job Brian.
Jake Kuhn
Very cool. What were those used on?
buckrancher
bolens 1957 super ride-a-matic with a different aircleaner and remote gas tank
Ken B
My 1950's Mercury outboards take the same coil...
VinsRJ
Great job Brian,
As soon as I see one of those Bendix ignitions I swap out the bearing plate for a different one and throw that thing away, LOL!
roadapples
Nice job Brian. And I hate when the CNC machine in the garage is so noisy. LOL
  • Similar Content
    • bigbuck
      By bigbuck
      I had a fire in 2019 which destroyed my pole barns and some wheel horse tractors and parts. i'm looking for someone who can use the engine that went thru the fire. It is not pristine but there must be some usable parts
      please call George at 517-499-5678 for more info.
    • cJ_3D
      By cJ_3D
      Hey all!
      Replacing the drive belt on my 252-h. Anyone know the torque specification for the center screw when I put this pto clutch back on? I know it was on there tight it took a minute for the impact to break it loose. Thanks!
      CJ
    • bkarp@roadrunner.com
      By bkarp@roadrunner.com
      my magnum 12 kohler all of a sudden is blowing oil out of the carb. if rings are bad should oil be blowing out of the muffler.thanks for any help brent
    • Tinman1962
      By Tinman1962
      Recently got hold of a 656 it's has a "newer" 61/2 Briggs on it I don't believe that's right any ideas about that
    • Little Red Horse
      By Little Red Horse
      Hey all. I have a Electro 12 with a factory belly blade. It runs* and drives. I had used it to grade my driveway the last 6 yrs. Having moved I'm looking at my options on storing it or selling it. Frankly I have no idea what it is worth. I watched "ISaveTractors" video on 5 things to do with a new to you wheel horse/12hp kohler. (When i got it 6yrs ago) And went thru and did the adjustments and replaced the parts mentioned. It has been a good strong tractor for me until around July of this year. (2023)
      *Around July it started dying after running 20-30min. I replaced the carb (Chinese Amazon purchase) with one from isavetractors web site. That seemed to help it idle smoother(the old carbs jets wouldnt adjust), but it still dies at around 20-30min.
      So I've got 2 questions.
      1. What is it worth? (As-Is) and
      2. What do I need to do to fix it?
      Thanks yall!
