tommyg
Control valve O rings d-180
tommyg
Well, I assumed incorrectly that the O rings at the bottom of the control valve "piston" for lack of a better word, on my d-180 was a standard Toro issue. But Toro doesn't even show a break down of that valve. Anyone know if there's a place I can deal with to get an exact match for this thing or do I have to just find one that's "close" and hope for the best? It's the one that goes between the control valve housing and the spring assembly at the bottom of the valve. It has a cover over the bottom.  Not the O rings on the hoses. Will post a pic if I need to, but last time I tried, it said I didn't have any more picture space available. Whatever that means.
gwest_ca
You have this service manual?
Garry
woodchuckfarmer
NAPA has a good selection
JamesBe1
I doubt they are anything special.  I would take the old one off and take it down to the local hardware store.  Most places have a decent selection of orings.  Also, oring kits are pretty cheap in the internet.
Ed Kennell
Tommyg, You need to delete some of your attachments. you have exceeded your allowable storage for pictures.
Click on your (name) in upper right.
Click on your (settings).
Click on( manage attachments).
Check all( boxes) on right side that you want to delete.
Scroll to the bottom and click on( delete).
Good luck, Ed
tommyg
Garry, that link could be helpful. Thanks. I've been to 5 hardware and automotive places so far. No one seems to have anything that fat. Didn't think there was anything special about this O ring. Guess I'll just have to keep looking. Maybe a "kit" might be the best option. Ed, if I delete the picture attachments, won't that kind of make the posts irrelevant for others? Thanks for all the input, guys. I know there's gotta be one out there with my name on it.
Ed Kennell
:angry-nono: You are only allowed 8MB of space. When you exceed that you must delete some of the older attachments if you want to post new pics. You may want to reduce the size of the pics before posting to save some of your space.
bewford
Contact member roblawrance he has had these in the past
tommyg
Well, I may have found something at an the local Discount Auto. Borrowed my brother's vernier calipers to get a good feel for the size. I could easily find some that were the right OD, but the ID and cross section were always wrong. Looks like the cross section is an 1/8". I'll find out tomorrow if I was successful. Seems to fit perfectly. Too bad I have to put it all back together to find out! Keeping my fingers crossed.
tommyg
For what it's worth, the lower O ring is actually an oversize "special order" O ring. I found a 1/2" ID x 3/4" OD X 1/8 which still seems to do the trick. But it turns out that the issue was not with the lower O ring like I thought. It was the upper one. Oil was being forced out the top and draining down the control valve giving the appearance that it was leaking out the bottom. Replaced that with the same size as the bottom and I think I'm back in business now. Time will tell.
  • Similar Content
    • tractorboy79
      By tractorboy79
    • BuffaloD200
      By BuffaloD200
      '74 D-180
      My friction disc in gone on my clutch.  I saw the old post about making a new friction disc, so I'm not concerned about that.
      I managed to remove the front clutch plate and double v-belt pulley.  But I can't separate the two.  When I took the assembly off the spiraloc washer popped off on its own.  I HAVE READ THE MANUALS.
      So I should be able to just remove the pulley from the front clutch and continue with step 4.  The v-belt pulley is loose as all hell and flops around like a dead fish.  It seems to be hung up on a ring or bearing race.
      So my thoughts are grab a BFH or sparky the blue tip wrench.
      Is there an unpublished step 3.5, or some trick?
    • BuffaloD200
      By BuffaloD200
      Hey all,
      My '74 D180 has a lot of trouble pushing snow.  Weighted tires, but nothing else at this time.  I've found it gets stuck frequently and only one wheel spins.  Do these tractors not have a limited slip/locker arrangement?  How does everyone manage with the infamous one wheel peel?
    • BuffaloD200
      By BuffaloD200
      Hey all, I need to install a drive belt on my 75 D180 for my snowblower.  I've looked through a bunch of D-series owner's manuals, and none seem to mention replacement procedure.  The PTO pulley is fixed, save for engaging the PTO and there is minimal movement at the snowthrower pulley. There's no idler or tensioner as far as I can tell.  Do I have to remove the PTO pulley?  That seems to be a required service item.
      Same question for my 80 D200 as well really.
      Using the recommended 4L490W belt.
      Thanks
    • ihatephones
      By ihatephones
      I got a D-180 for $250, and the governor is messed up, the points won't open or close, and I took it apart and was being stupid and messed some stuff up in there, and now I need a new one.
      Where can I get one that's not on eBay for $200?
      I also forgot to say it was a Kohler K482, and I'll throw some pictures of the tractor in as a treat.
