BruceM 0 #1 Posted September 9, 2013 Have a 1995 Toro/Wheelhorse and the drive belt needs to get changed. Looks a bit complicated, Can anyone offer insight? Thank you! Share this post Link to post Share on other sites
shallowwatersailor 3,213 #2 Posted September 9, 2013 It is a bit of work. Reminds me of when I had an '83 Honda Accord and had to pull an engine mount to change a belt! The Toro 260-series Repair Manual pp. 3-6 to 3-12 does have a 26 step procedure with nice clear photos, but you need to disassemble some of the tractor and work underneath to install it. The job does appear do-able by the average owner with tools though. GOOD LUCK! Share this post Link to post Share on other sites
CTBT&D 77 #3 Posted September 15, 2013 I replaced the belt on a 1993 266H, about 3 hours without a manual. Craig Share this post Link to post Share on other sites
Whmaverick 54 #4 Posted September 29, 2013 I changed drive belt on a 98 265-6speed and it was 3 hrs of torture. Gotta prop the tractor up so you can lay under it, drop the peddles and steering mech. And after cussing toro a bunch, I was almost done, No help from manuals just blundered through it and hope to never do another one. Good luck and may the wrench gods be with you. Share this post Link to post Share on other sites
