Kelly 1,030 #1 Posted August 25, 2008 I have a pair of rear wheel weights for a WH that look like these but mine have 4 mounting holes, and do not have the cut out for a valve stem, are these WH or other?? I know they probably had other company's make their weights. Share this post Link to post Share on other sites
Kelly 1,030 #2 Posted August 25, 2008 Duh, it would help if I post the link. http://cgi.ebay.com/SET-OF-WHEEL-WEIGHTS-F...1QQcmdZViewItem Share this post Link to post Share on other sites
C-Series14 15 #3 Posted August 25, 2008 Same as I have, I have the matching front and rear and 99 percent sure mine are WH. I will look tomorrow and see if there is a part number on mine... Share this post Link to post Share on other sites
pond195520032003 27 #4 Posted August 25, 2008 Kelly, they are the same, just the ones with the valve stem notch could be used on the D series and the others cant i have a pair without the notch (see allachments picture section) look under wheel weights as i and someone else posted pics! either seat can be used on all the other 12" wheels but the inside of the D wheels are much larger :banghead: Share this post Link to post Share on other sites
