Similar Content
By edwroy
Needs some help. Purchased an ARK Loader - Model 550 Serial # 573 - anyone know what year this might be?
Thanks,
Edwroy
By chevyaddict83
So, i ended up rebuilding curl pistons, worked great. Now, having lift issues. If i pull on the lift lever slightly, i still get the arms to go up. If i pull all the way back, the whole thing drops. If i leave it raised and fill the bucket, it stays up and dumps fine. Is it something in the control valve? Maybe an adjustment?
Sent from my LG-LS980 using Tapatalk
By prondzy
So i have an ark 508 loader on my c160. I was wondering if any of the other Ark FEL owners could tell me if there is a "float" postion in the spool valve?
By bo dawg
Is it hard to pull apart to replace seals? Any tricks? Or things to watch for?
By JackC
I acquired an ARK 550 loader for my D-200. After I got it installed and tried to use it, the bucket cylinders would not hold the bucket in position with weight in the bucket. It appears that the cylinders need to be be rebuilt. I can move the cylinders and bucket up or down by pushing one way or the other. I assume the control valve is OK but don't know.
I checked with a shop that does hydraulic repairs and it sounds like it would be about $100 per cylinder to rebuild them and two weeks because the shop is very busy.
Does anyone have experience rebuilding these cylinders, have a link to a repair manual and know the parts and tool needed?
Thanks,
Jack.
