daemon2525 5 #1 Posted August 23, 2008 Can anyone tell me for sure what direction the oils seals go in on a k301? I would assume that the cup side goes inwards, but I took them out without looking and the only other engine that I have has the cup facing outward on the flywheel side. The pto side the cup faces inwards like I would assume. It is very possible that the "other Engine" is wrong. Share this post Link to post Share on other sites
WH854 45 #2 Posted August 23, 2008 Any oil seal I have ever installed the metal part was on the outside. But I am not a pro! TT should be able to tell you. Chas from Butler Pa. B) Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #3 Posted August 24, 2008 The lip of the seal points inward. (the flat surface goes to the outside) B) Share this post Link to post Share on other sites
